I need a favor... anyone in the SW Chicago burbs? - JeepForum.com
post #1 of 7 Old 11-21-2009, 08:39 PM Thread Starter
unsung
unsung's Avatar
I need to weld sockets on to these locking lugs that the key is stripped out for. I do not possess a welder though. I'm also looking to find someone that can help asap as I have brake work that needs to be done.
So if anyone is interested, I would compensate, simply for welding on five sockets to five lugs to five wheels.
Thanks!
unsung is offline
post #2 of 7 Old 11-21-2009, 09:47 PM
GRN_BEAST95
why dont you go get a new key. its probably gunna cost way less than wasting 5 sockets. im sure the dealership has one.
1995 YJ emerald green
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Green Jeep member 153
Originally Posted by yellojeeper View Post
Guam. I spent a week there one night.
GRN_BEAST95 is offline
post #3 of 7 Old 11-21-2009, 10:31 PM Thread Starter
unsung
unsung's Avatar
It isn't that easy. McGard makes the key and they either want the code from the card that comes with the key, which I don't have, or I have to take foam off a coffee cup and get the pattern by imprinting it there and sending it in. Plus they also want a $15 check to replace their lifetime warrantied part.
I'd rather do away with the locks altogether so I bought a cheap socket set from autozone. So I want to weld them on so I can remove the locking lugs once and for all.
unsung is offline
post #4 of 7 Old 11-21-2009, 11:04 PM
JohndKc
1987 YJ Wrangler
I don't understand. The nuts are stuck on the hub. You can drive them off with a cold chisel and a hammer. I have done this before. Time consuming but not that hard, I had to do about 5 and it took about an hour.
Craftsman 3/8 x4 in. Cold Chisel
You could also use a nut buster. I don't know how well it would seen as i have never used one but i like the idea. I guess there is a possibility of you damaging the studs, but you can be gentle so to speak.
Craftsman Nut Cracker
hope that gives you some cheap fix ideas.
-John
JohndKc is offline
post #5 of 7 Old 11-21-2009, 11:05 PM
JohndKc
1987 YJ Wrangler
Well either one of my methods will destroy the nuts.
-John
JohndKc is offline
post #6 of 7 Old 11-30-2009, 06:10 AM
464steelman
I had the same problem and took a thin wall socket and hammer and drove the socket onto the lock. Used a breakerbar and put even presssure on it and came right off. It worked 4 times on four locks.
464steelman is offline
post #7 of 7 Old 11-30-2009, 08:35 AM Thread Starter
unsung
unsung's Avatar
I ended up doing the same thing, thanks.
unsung is offline
SNOW Pics, Philly burbs Ron Burgundy North East USA 1 02-13-2010 08:55 AM
philly burbs run part deux funshootin1 North East USA 1 10-02-2009 04:06 PM
ne phila burbs run sat 1st funshootin1 North East USA 8 09-05-2009 12:57 PM
Any of you looking for an XJ in CHI burbs (not mine) XJREWSTER Illinois Jeep Forum 0 03-27-2009 05:17 PM
