Parker Desert Splash 19th annual event 7th-9th of Nov. - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > Arizona Jeep Forum > Parker Desert Splash 19th annual event 7th-9th of Nov.
Halloween Savings to die for!ZONE 4.25" combo lift for TJ available at Rockridge4wNEW!! HMF 50"-52" light bar mounting brackets!!
Unread 09-02-2014, 02:26 PM   #1
222Doc
The Parker splash is coming soon.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 10-05-2014, 07:57 PM   #2
ericksin
1982 CJ7
Hey Doc, What are they going to have you doing this year?
**** it, GAS IT!
ericksin is offline   Reply With Quote Quick reply to this message
Unread 10-05-2014, 09:06 PM   #3
222Doc
depends on the drivers meeting in the end. I am open to lead the ones i know well enough. Will tail gun. Planning to run 3 days of trails. Lets hope it cools down a bit more.
Unread 10-10-2014, 02:25 PM   #4
222Doc
We are pre-running them all this next 4 weeks. The heavy rain this summer flash flooded most of the trails up the county road to the bar. This effects many trails. I have heard from a few guys that have ran them since the flood that they are a lot harder.
I think i am going to cover the easy trails. There may not be to many this year since rain was made most the sand go away. But i am looking at Cattail/ maybe adventure if its not washed out and a 5 now. Maybe Vampire mine? again that would have to be pre run as it could be gone. Going to a a busy month. weather is getting nice.
Unread 10-10-2014, 05:21 PM   #5
ericksin
1982 CJ7
Very cool ....... looking forward to meeting up with you guys again!
**** it, GAS IT!
Unread 10-11-2014, 12:48 AM   #6
Dillard
Would love to meet up with guys from the area to go Jeep'ing!
Dillard is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 08:42 AM   #7
ericksin
1982 CJ7
Cj
Cool man, we do a lot of stuff with AZ4x4CLUB, there based out of Phoenix. we do some runs for them up here from time to time.... I will PM you latter I don't want to Highjack 222DOC's post are you going to the Parker Splash?
**** it, GAS IT!
Unread 10-12-2014, 02:56 PM   #8
222Doc
Just got in from running Presidents / Deliverance and part of Adventure. President was 3+ now 4/4.25. Going to be rough on 35"s. Deliverance is harder now, even after we filled in the BIG hole at the first big fall, i had to winch it, the other falls are taller now and with a 2d is a bit of a pucker. Adventure trail is closed until we get back out there next week, some big rocks slid down and filled the area that was tight and had a fall in it. we need to check the side rocks to see how unstable it is. might have to set the rest of it off.
President seems to have changed the most. The area after launch pad is very washed out. what was the hard way there is now the easy way and still hard 3+4 and the hard way now has two options and both are hard 4.5+ watched a few buggies get through. launch pad is harder and less sand in the pit.
Unread 10-12-2014, 08:08 PM   #9
ericksin
1982 CJ7
Cj
:cheer s2:
**** it, GAS IT!
Unread 10-13-2014, 01:44 PM   #10
222Doc
come out on the desert bar(back way road). The trail is only a bit harder than before, mainly the start when you climb up still over all its just a bit rougher and still in the 2 range.
Unread 10-24-2014, 10:13 PM   #11
ericksin
1982 CJ7
How's it looking out there Doc?
**** it, GAS IT!
Unread 10-25-2014, 09:32 AM   #12
222Doc
last week we cleared Adventure, rock slide blocked 1st obstical area.
i think the trail is still rated about 3/3.5 depending on jeep. the last section of boulder alley i think got easier but the rocks are larger. less loose dirt.
over all the trails are harder do to the lack sand at the bottom of many of the falls. trails like president was affected the most since it is at the bottom of the canyon and the final funnel for the water to pass. that trail is now 4.25 to 5 depending on line.
should be fun with the changed terrain this year.
Unread 10-25-2014, 09:49 AM   #13
ericksin
1982 CJ7
Sounds good, see you there
**** it, GAS IT!
