Lift install in Phoenix area - Page 2 - JeepForum.com
post #16 of 31 Old 03-22-2012, 06:35 PM
ZJFABN
Originally Posted by tarbucketmike View Post
LIke opinions, EVERYONE'S GOT ONE.
I have personal experience with Todd over the last two winters.
He has vast experience, welding skills are impeckable and ALL my work has been "under priced" IMO
I would not have recommended him other wise.
Facts are not opinions.
You fall into the 90% of customers that are happy with him. The other companies I listed are closer to 100%. Have you heard anything bad about the other companies? Have you used them. Just because your happy with just one doesn't mean they're the best choice. Just sayin.
My work, http://www.virtualjeepclub.com/showthread.php?70963-JW-Fabrication&highlight=Jwfabrication
ZJFABN is offline
post #17 of 31 Old 03-22-2012, 08:36 PM
Billy
Billy's Avatar
hows your search coming?
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
post #18 of 31 Old 03-22-2012, 08:46 PM
SandDevil93
Originally Posted by ZJFABN View Post
4wheelerssupply is also good. Talk to Simon or Barry and don't forget to mention the %10 VJC discount (i think I've seen you around there)
Don't ever trust your vehicle with four wheel parts.
X 2
Recommend 4wheeler Supply on Washington St. They're golden.
4 wheel parts in Mesa, I won't go there again.
SandDevil93 is offline
post #19 of 31 Old 03-23-2012, 09:46 PM
thatoneguyaz
I have an appointment at Desert Fab on Wed of this coming week!
It was between Desert Fab and Letzroll Offroad - It was hard to chose but Todd is doing an alignment after as well which is included in the price - and I don't think Letzroll Offroad offered me anything like that. The only part that really sucks is how far away Desert Fab is
IRO 4'' LONG ARM CRIT PATH - 285/75/16 GRABBER AT 2S - ADJUSTABLE TRACK BAR - QUICK DISCOS
thatoneguyaz is offline
post #20 of 31 Old 03-23-2012, 11:05 PM
ZJFABN
An alignment is part of the install. It has to be done or you wouldn't be able to drive it after the install. Hope Todd didn't act like it was a favor. Any honest shop will tell you its part of the install.
Letzroll is closer. Just sayin. I guarantee you won't be disappointed!
ZJFABN is offline
post #21 of 31 Old 03-25-2012, 08:37 PM
thatoneguyaz
I see. No not really he seemed very straight forward. It is closer but I already made the appointment.
post #22 of 31 Old 04-04-2012, 02:37 PM
ZJFABN
So what happen with desert fab and the alignment?
http://www.jeepforum.com/forum/f320/...oenix-1352484/
ZJFABN is offline
post #23 of 31 Old 04-04-2012, 03:50 PM
thatoneguyaz
No idea man. He told me "centered the steering wheel" .....
post #24 of 31 Old 04-04-2012, 04:01 PM
ZJFABN
He might have done the rest too. You would know it if he didn't adjust the toe. And casters all that left. Usually if you follow the directions on the lift, the casters pretty close.
What's with the knocking sound that you mentioned on Vjc? Was it doing this before the install? Any good shop would have checked this out and advised you on it.
ZJFABN is offline
post #25 of 31 Old 04-13-2012, 05:39 PM
ajmadic
Andrew at letzroll is the best out here in AZ.
05 Rubi; she goes by Ragu.
ajmadic is offline
post #26 of 31 Old 04-13-2012, 09:21 PM
thatoneguyaz
Seems to be gone.
I'll be going elsewhere probably to LetzRoll or Absolute Offroad for any further work mainly because driving out that far wasn't worth it the first time, probably wont be the second.
post #27 of 31 Old 07-18-2012, 09:43 PM
thatoneguyaz
So I ended up going to Desert Fab and ever since my first run my Jeep has made all these weird suspension related sounds when turning, when on a bump trail things like that. And I'm still learning all this stuff and have little to no skills working on a vehicle. The jeep sure is teaching me though. Well anyway I discovered last night that the bolt for my drivers side control arm was never tightened properly. And was almost all the way out, caused me a death wobble, a horrible tire-to-bumper rub, and a jacked up alignment.
The problem has been corrected now, but I don't think I made the right decision for who to install my lift.
post #28 of 31 Old 07-18-2012, 09:46 PM
EBT531
Did you check the bolts after the first couple hundred miles and after the 1st real trail? Mine loosened up a couple times then have been good ever since
1998 5.9ZJ, 231 TC w/SYE, IRO 4.5" Lift, IRO Adjustable CA's, Bilstien shocks, IRO Sliders, MVC Truss Rear, High Angle Driveline Front and rear shafts, 4.56 gears
EBT531 is offline
post #29 of 31 Old 07-19-2012, 06:13 PM
222Doc
222Doc's Avatar
If the bolts were set to spec, no way the way this should have come apart, matter of fact even if he was on 4's+. But to oneguyaz, as a RULE of being an "Jeeper" is to know your ride it is your horse. ANY thing feels funny, you stop and check. After runs its a good idea to take look under for loose bolts, bent stuff.
If this happened right away after the lift was installed they left a loose bolt/. lucky no one got hurt. Did they fix this? any wobbled out ruined parts looks like it from the way its jacked up
222Doc is online now
post #30 of 31 Old 07-21-2012, 12:46 PM
ZJFABN
Thatoneguyaz,
Clear your pm box. I can't reply to your pm.
ZJFABN is offline
4x4 shops in Phoenix area mlstudey Arizona Jeep Forum 12 10-19-2010 12:25 PM
Moving to Arizona... Phoenix area within 50 miles... where not to live? aaron7 Arizona Jeep Forum 37 07-17-2010 12:23 AM
Phoenix Area! willhbauto Arizona Jeep Forum 25 10-01-2008 08:31 PM
Looking to start a club in the Glendale/Phoenix/Peoria area. The Donger Arizona Jeep Forum 2 09-29-2008 04:08 PM
