the gap/ chiva falls tucson.az - JeepForum.com
post #1 of 8 Old 02-15-2011, 09:45 PM Thread Starter
carbert
Was wondering if a stock 93 yj 4.0 inline 6...can make this trip...the only mode are shackles tht were on whn I bought it..and 31x10.5x15 firestone destination m/t
carbert is offline
post #2 of 8 Old 04-03-2011, 07:25 PM
MxM
You could prob make the falls stock...but you would have to be really careful.
MxM is offline
post #3 of 8 Old 04-04-2011, 07:09 PM Thread Starter
carbert
I've nver been tht way..ther a lot of obstacles (challenges)
carbert is offline
post #4 of 8 Old 04-04-2011, 10:32 PM
Gman1128
You could make it to Chiva Falls stock. There is an easy way to get there that will let you bypass the only spot a stock vehicle would have any trouble, a large obstacle called 3 Feathers. I made it back when I was stock but on 31's so I had like no flex. I've seen an almost stock Liberty able to make it and I've seen stock Chevy trucks out there, so I don't think you'd have a problem. You could even probably make it up or down 3 Feathers if you had a good spotter
However, I would not recommend trying to run the Gap stock, its a very rough trail, I tried it stock, didn't make it too far...
Gman1128 is offline
post #5 of 8 Old 04-05-2011, 11:24 AM
MxM
the gap is extremely rutted. You need lots of clearance and flex. I had a TJ that had 4in lift and 33's and i made it fine. I've seen stock TJ's out there...but its sure a lot more stressful because there are lots of rocks out there to break stuff. Def go to Chiva though. its a great trail! Esp right now the falls might be running becuase of snow run off.
MxM is offline
post #6 of 8 Old 04-05-2011, 11:39 AM
dwayTJ
Charouleau Gap used to be difficult and very rutted, but unfortunately the USFS has bulldozed the hell out of it recently. They started last January from the Catalina side and just started again where they left off a few weeks ago. They're probably almost halfway through by now. I've had a buddy's stock 4 cyl YJ on 31s out there recently with no major problems. There are still a few small boulder crossings that might give you trouble, but with a good spotter you'd be fine. We took a stock JK Sahara all the way through about a month ago. For reference, last January they took Kiss Rock, the coolest obstacle on the trail, from this
to this
You'd be fine at Reddington/Chiva Falls, just make sure you're disconnected or you'll have a hard time getting back up Three Feathers. I've run that trail with lots of Jeeps on 31s.
dwayTJ is offline
post #7 of 8 Old 04-05-2011, 08:07 PM Thread Starter
carbert
I appreciate the info...I guess the gap will have to wait till I get a lift and 33..... but good to knw tht the chiva falls will be ok to run.....hay if I get stuck I'll call you guys to help.....LOL
carbert is offline
post #8 of 8 Old 04-06-2011, 11:04 AM
MxM
Did they really bulldoze it that much?!?!?! Wow. That stinks. I love that trail because its hard.
MxM is offline
Tucson AZ - Chiva Falls Wheelin' - Sat Nov 6 @ 9a skivviss Arizona Jeep Forum 5 11-05-2010 09:33 AM
Hidden Falls run (marble falls, Texas) AustinTexasXJ South Central USA 1 03-09-2010 11:50 AM
Tucson AZ Wheeling??? snellav Arizona Jeep Forum 11 05-16-2009 06:32 AM
