Weird thunk noise when engaging clutch. - JeepForum.com
post #1 of 9 Old 11-26-2012, 09:30 PM Thread Starter
YJYNOTJ
Tj Weird thunk noise when engaging clutch.
I've got a 03 rubicon I've had for about a month now. Not sure why I didn't notice it before I bought it, but I've got a weird thunk noise when disengage the clutch... mainly between 1-2-3 gears. If I let the pedal out real slow it's not there. Almost reminds me of auto lockers will suddenly engage or disengage.
I can also replicate the noise by letting it coast a little and then hitting the gas hard. So seems to be related to when torque is applied.
Shifts, really smooth other than that. Way better than my YJ did. Searching the interwebs seems like it could be a couple of things:
1. U joints going out.
2. Transmission, transfercase or motor mounts are lose or bad.
3. A bent fly wheel.
U joints look ok, there no slop or noise when I'm under it and try turning the rear driveshaft. When it's in gear I can turn it at all.
I know that the motor mounts are fairly new... look good from what I can see.
I can't see and obvious place underneath that it's hitting if something is loose under there.
Anyway, anybody experience something similar?
2003 TJ Rubicon
93 Wrangler YJ (Sold)
08 Liberty KK 245/75R16 | 3.5 front 2.5 rear RockKrawler Lift
YJYNOTJ is offline
post #2 of 9 Old 11-26-2012, 10:00 PM
Mickey_D
Believe it or not, check your control arms. Specifically the end links. My first thought is that the axle is trying to rotate around the shafts (if that makes sense). On a leaf sprung vehicle what I'm talking about would be called axle wrap.
A bent flywheel wouldn't be noticeable with the clutch fully engaged. It would only act up when there was slippage on the clutch with power applied. It would also be worse the more power was applied. And it wouldn't be a single clunk, it would be a repetitive chatter (been there, done that).
What you're describing sounds more like a mount. Specifically engine, trans or xfer case.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 9 Old 11-26-2012, 10:26 PM Thread Starter
YJYNOTJ
Interesting, I just crawled under it and rear driver control arm I could shake it enough to have it make "clunk" noise. Not nearly as loud but I can't torque it like the rear axel can. I couldn't get any of the other arms to make any movement.
So I guess the fix is new bushings? Thanks for the info
2003 TJ Rubicon
YJYNOTJ is offline
post #4 of 9 Old 11-26-2012, 10:47 PM
Godholio
Check your fluid levels too. I was pulling my hair out trying to figure out a transmission noise in my other car before I decided to check the fluid...which was down to 1/3 the proper amount.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #5 of 9 Old 11-27-2012, 05:44 PM
Mickey_D
Perfect time to swap out for adjustables for a lift!!
________________
#4
Mickey_D is offline
post #6 of 9 Old 11-27-2012, 06:12 PM Thread Starter
YJYNOTJ
Yeah just need to find $1500 in my couch cushions.
2003 TJ Rubicon
YJYNOTJ is offline
post #7 of 9 Old 11-27-2012, 08:29 PM
Mickey_D
I hear ya. Believe me I do.
________________
#4
Mickey_D is offline
post #8 of 9 Old 11-28-2012, 03:51 PM
cbandit
Talk to aj at Teraflex. Tell him you're a member of the ujc and he will prob give you a discount. Do just the arm and its counterpart for now to save some cash
cbandit is offline
post #9 of 9 Old 11-28-2012, 04:09 PM Thread Starter
YJYNOTJ
Having only had it a month, not sure but I think they are Rubicon Express Short Arms that came with the 4inch lift, defiantly not adjustable. The one I think that is the problem has quite a bit of rust around the lower bushing.
Yeah I've thought about just replacing them all with a cheaper short arm kit, at least the rear ones for now.
Teraflex is and option, I've thought about the Jonny Joint kits, any thoughts from anyone best flexing short arm kits?
2003 TJ Rubicon
YJYNOTJ is offline
