Utah Dub Club.. I need help. - Page 2 - JeepForum.com
post #16 of 29 Old 12-04-2012, 06:32 PM
PowderPusher
1978 CJ5
i had a wobble at 35-45mph until i switched my front and rear tires. the wobble is almost completely gone. there are only a few on ramps that it will do it a little for maybe a second. i was told that mtr's wear kind of funny when they are at 30psi or more.
PowderPusher is offline
post #17 of 29 Old 12-06-2012, 01:13 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Your issue is probably the tires. I kept getting dw with my Xj I tried rotating which helped and my tires would balance out still had dw I bought new tires and the issue went away
Sent from iPhoneusing JeepForum
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #18 of 29 Old 12-07-2012, 05:39 PM Thread Starter
BLACK04WJ
thanks for the responses everyone! I dont have a whole lot of time to work on it because of school and work but its my #1 priority!
today i adjusted my caster, changed steering stabilizer (old one was new but i checked it and it was shot somehow) with a moog super trail boss! right now the jeep is at a local shop getting toe-in set to IRO specs. also i changed the trackbar bushings even though the old ones looked good still.
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #19 of 29 Old 12-07-2012, 06:38 PM
team1k
Sweet! Are you driving it up here tomorrow?
It was a Jeep thing, but all that stuff broke
92 Jeep YJ Wrangler
UJC
"YJ's are for poor people" - Brian
team1k is offline
post #20 of 29 Old 12-07-2012, 06:46 PM Thread Starter
BLACK04WJ
well I'm coming in Sunday now.. but it depends on how the test test drive goes tomorrow if not, I will still be in a WJ.. just a smaller one my wife's 2004 Laredo on a 2" lift.
Oct '12 GCOTM
post #21 of 29 Old 12-07-2012, 07:03 PM
team1k
Is it silver? If it is i for sure want to see it because thats what my wife has, although its the "Special Edition" not Laredo. Close enough. What size tires have you fitted with the 2" lift?
92 Jeep YJ Wrangler
UJC
team1k is offline
post #22 of 29 Old 12-07-2012, 08:02 PM Thread Starter
BLACK04WJ
no, hers is the same color as clgielin's WJ. but mine is silver
i havent gone up in tire size since its a street queen..for now. I think it looks good how it is set up
Oct '12 GCOTM
post #23 of 29 Old 12-12-2012, 01:21 AM Thread Starter
BLACK04WJ
Well, I threw my wife's tires on the WJ and drove around.. no shake at all!! got going about 90 mph and still nothing.
I'm still not 100% sure my tires/wheels are bad per se. I'm thinking its just the weight of them is causing a slight "play" with the steering. I tightened the steering box slightly and it was a pretty big improvement. I also noticed that the nut holding my pitman arm has fluid on it. is there a seal that could have gone bad in the lower end of the box? I'm thinking since my jeep has "wobbled" so many times that it has cause the "play" in the box. I'm going to re-tighten the box a little more tomorrow and report back.
I know over tightening the box is not good.. I'm not even turning it 1/4 turn between test drives
Also.. here is what a WJ with 6.5" of lift looks like with stock wheels and tires
Oct '12 GCOTM
post #24 of 29 Old 12-12-2012, 01:28 AM
team1k
There is a seal in the box on that shaft that could have failed. I would check the lines and fittings going into the box though as usually for me that was leaking and not the box.
92 Jeep YJ Wrangler
UJC
team1k is offline
post #25 of 29 Old 12-12-2012, 01:35 AM
85IrocZ-28
I have heard of "tightening" the steering box before, do you have any more details you can share? I have some play in my steering, and it is not from a tie rod or anything else external that I can see.
And...those tires look awesome with the front flares
Seriously though, it is good to hear you are tracking down the issues.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #26 of 29 Old 12-12-2012, 01:35 AM Thread Starter
BLACK04WJ
sounds good, ill check that as well. I checked the local parts store just to see how much a new box would be and it was like $250 but $112 was a core charge.. hope the box doesn't need replaced
Oct '12 GCOTM
post #27 of 29 Old 12-12-2012, 01:40 AM Thread Starter
BLACK04WJ
if you look at the top of the steering box, it will be easy to see how it works.
there is a nut on top of your steering box (16mm IIRC) that you back off and then use an Alan wrench(cant remember what size) to tighten the bolt inside the nut. DO NOT over tighten.. you will ruin your box if it is too tight.
IIRC
Will, your stock air box might be in the way to easily access this.. but I could be wrong. your air box is different than mine.
Oct '12 GCOTM
post #28 of 29 Old 12-12-2012, 02:22 AM
team1k
Be careful with that screw. What it does is set the backlash inside the box. Generally it shouldn't be touched just like you never change your differential backlash after its set properly.
That being said lots of people tinker with it and get varied results. Some good some very bad. Just make sure to mark where it was when you started.
92 Jeep YJ Wrangler
UJC
team1k is offline
post #29 of 29 Old 12-12-2012, 02:31 AM Thread Starter
BLACK04WJ
I have heard that too but most cases on the WJ I have read have good results as long as they only tighten a little bit. (as needed)
also, the screw doesn't stick out.. so there is no way to mark it. just have to remember how far you have turned it.
Oct '12 GCOTM
