Utah Dub Club.. I need help. - JeepForum.com
post #1 of 29 Old 12-03-2012, 11:38 PM Thread Starter
BLACK04WJ
as most of you know, this WJ is my first vehicle I've done anything to.. so I'm a noob haha. I've been trying to fix my death wobble issue and I've fixed a few things but still have a slight shake at highway speeds. let's hear your ideas!!!
so far I've done the following
new draglink with new TRE's
fixed track bar mount (it was oval lol)
new upper CA bushing (3 link)
ball joints/hubs/bearing are all good
here are the current alignment specs..
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #2 of 29 Old 12-03-2012, 11:41 PM
801DubJay
Have you balanced the tires or checked the SS?
'00 WJ Laredo V8 aka Katie
My Build Thread: http://www.jeepforum.com/forum/f197/801dubjay-build-thread-1114628/
801DubJay is offline
post #3 of 29 Old 12-03-2012, 11:44 PM Thread Starter
BLACK04WJ
balanced the tires myself and it's the second SS
Oct '12 GCOTM
post #4 of 29 Old 12-03-2012, 11:47 PM
801DubJay
Dynamic balance? Have you also checked for roundness? (I believe that's what it's called - tire needs a surface pressure test as it rotates) Occasionally the belts will shift inside the tire causing it to hit the surface unevenly, acting like an unbalanced tire which can trigger dw.
post #5 of 29 Old 12-03-2012, 11:53 PM Thread Starter
BLACK04WJ
hmmm haven't heard of the roundness. the tires are new and I've only put a couple thousand miles in them.
Oct '12 GCOTM
post #6 of 29 Old 12-04-2012, 12:01 AM
801DubJay
If you are confident the tires are well balanced, the only other things I could suggest is to check every bushing on the TB and CA's and make sure they aren't worn. And, try swapping your front tires for the back ones and see if dw changes. If dw still occurs but at a different speeds, then there is a balance issue with the tires. AND if it doesn't occur, then there is a balance issue as well. Also check for wear on the tires, perhaps the shoulders are wearing at different rates and the contact patch is off.
post #7 of 29 Old 12-04-2012, 12:09 AM Thread Starter
BLACK04WJ
sounds good, thanks Matt! I checked the track bar bushings and they looked good. I have new ones so maybe I'll just throw them on anyways.
Oct '12 GCOTM
post #8 of 29 Old 12-04-2012, 12:13 AM
311LJ
311Popo
311LJ's Avatar
I think it's just the roads in price ha ha JK looks like Matt has it all about covered. Rotate tires and report back.
John
04 TJ Unlimited, GenRight Armor, 37's Unlimited Build Thread
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY* WJ Build Thread
*UTAH JEEPCREW #01*
I ♡ John
311LJ is offline
post #9 of 29 Old 12-04-2012, 12:47 AM
team1k
My YJ:
Tires out of balance?
Most definitely
Trackbar mount and bushings ok?
Don't have one
Steering stabilizer ok?
Don't have one
Bushings on CAs worn out?
Don't have those on the front but the leaf spring ones are shot.
Got death wobble?
No
Posts like these make me very afraid to build up my wife's grand
It was a Jeep thing, but all that stuff broke
92 Jeep YJ Wrangler
UJC
"YJ's are for poor people" - Brian
team1k is offline
post #10 of 29 Old 12-04-2012, 03:33 AM
team1k
Also I'm no expert in alignments but shouldn't all those red items be green? Red bad green good? Seems like that's an issue.
92 Jeep YJ Wrangler
UJC
team1k is offline
post #11 of 29 Old 12-04-2012, 08:47 AM
801DubJay
Originally Posted by team1k View Post
My YJ:
Most definitely
Don't have one
Don't have one
Got death wobble?
No
Seems like you're comparing apples to oranges! I can tell you that the Oranges are known for DW after being lifted, but it is maintainable. However, it does require a little more attention than other rigs.
post #12 of 29 Old 12-04-2012, 09:09 AM
Tuffjeeper
I know that the suspension designs are slightly different, but this could be part of it.
Have you checked your caster angle?
Stock jeeps are around 9* but lifted jeeps need to be around 5* caster because of the tire differences.
The Tuff Jeep Build Thread
Originally Posted by plrbear View Post
Destroyed it somehow..... It went wobble wobble wobble boom
Tuffjeeper is offline
post #13 of 29 Old 12-04-2012, 09:58 AM
85IrocZ-28
Toss your wife's tires on for a day and see how it feels. That will allow you to completely eliminate the tires from the equation.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- Project Yeti Build Thread
85IrocZ-28 is offline
post #14 of 29 Old 12-04-2012, 12:58 PM
team1k
Like^
92 Jeep YJ Wrangler
UJC
team1k is offline
post #15 of 29 Old 12-04-2012, 02:07 PM
00JGC00
If I had a nickle for every time I've posted that on JF....
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
