Trying to help a friend, Looking for a rear axle assembly - JeepForum.com
post #1 of 12 Old 11-12-2013, 10:11 PM Thread Starter
Tblack
Recently had a friend blow through his Dana 35 on his YJ with 3.55 gears. It is completely stock and he is looking for anyone that has one they need to part with. Any help is great,
Thanks!
Safety 3rd!
Tblack is offline
post #2 of 12 Old 11-13-2013, 12:41 AM
team1k
Originally Posted by Tblack
Recently had a friend blow through his Dana 35 on his YJ with 3.55 gears. It is completely stock and he is looking for anyone that has one they need to part with. Any help is great, Thanks!
I bet russ(dr. Jeep) has got to have one.
It was a Jeep thing, but all that stuff broke
92 Jeep YJ Wrangler
UJC
"YJ's are for poor people" - Brian
team1k is offline
post #3 of 12 Old 11-13-2013, 07:35 AM
Mickey_D
Not sure if it would help, but there's an XJ half torn apart near the corner of Industrial Parkway and 1200 N in Orem. Most everything is gone from the front end, but I know that as of last Saturday the rear axle was still under it.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #4 of 12 Old 11-13-2013, 10:12 AM
Moparich
i got a d35 out of a ZJ with 3.55. i just swapped it for a 44 but it ran good
UJC #174
Moparich is offline
post #5 of 12 Old 11-13-2013, 10:40 AM Thread Starter
Tblack
I am wondering if it will bolt right up to the YJ.
Safety 3rd!
Tblack is offline
post #6 of 12 Old 11-13-2013, 11:11 AM
team1k
It won't. It would need the coil buckets cut off and the leaf perches welded on. XJ axles won't work either without welding since they are spring over. MJ(Comanches) are spring under but are an inch or two wider on the perches.
Your only option that is bolt in is a YJ axle.
92 Jeep YJ Wrangler
UJC
team1k is offline
post #7 of 12 Old 11-19-2013, 04:07 PM
Tuffjeeper
Or just weld the leafs to the coil buckets...
Tuffjeeper is offline
post #8 of 12 Old 11-23-2013, 10:32 AM
YJ475
Call Russ (Dr. Jeep). He's sure to have one or three, or know where to find one.
YJ475 is offline
post #9 of 12 Old 11-23-2013, 10:35 AM
dahreno
If you want to help your friend , give him the info. he needs . Don't get another 35 , move up to a 44 . Just my 2 cents
dahreno is offline
post #10 of 12 Old 11-23-2013, 11:56 AM Thread Starter
Tblack
well, its stock and he isn't the offroad jeeping type. He will never go bigger than the stock sized yj tires.
Safety 3rd!
Tblack is offline
post #11 of 12 Old 11-24-2013, 09:03 PM
dahreno
Yah but , he still broke the 35 , right ?
dahreno is offline
post #12 of 12 Old 11-25-2013, 04:53 PM
Tuffjeeper
I don't see a problem with him running another 35 if he doesn't go bigger. I wheeled trails like Hell's Revenge and Poison Spider back in the day with 33's on my 35. I then upgraded to a Super 35 and it ran years without issue. It could have been the p.o. who did something stupid in it, then the slightest thing your buddy did, ruined the axle.
In my personal experience, if you don't treat it like a 14 bolt, and recognize its a 35, you can go quite a ways with the stock 35.
At any rate, that being said, 8.8's or C8.25's are going for around $100-$150 (I paid $75 for mine at Pic-A-Part with everything but discs & pads), about the same price as a D35. With about $50 in bracketry it wouldn't be too hard to get one of those under it either.
