Transmissions - JeepForum.com
post #1 of 3 Old 06-19-2013, 11:45 AM Thread Starter
bradentaala
Transmissions
It's time to upgrade... I have an LS1 laying around and i'm finally putting together a gameplan to get it into the jeep. I'll be doing a different transmission at the same time and wanted to see what you all think. Here are the 2 options i'm looking at:
1. AUTOMATIC: TH400 with reverse manual valve body and engine braking. With the reverse throw it puts 1st gear closer to reverse for the quick shift when needed. Combined with a Winters / Art Carr shifter.
2. MANUAL: SM465 4 speed
'00 TJ, 14" coilovers, teraflex speedbumps, double triangulated 4 link, 3 link, D60, 14 bolt, 42" Kevlars, 17" walker evans beadlocks, high lines, 104" wb, atlas 4 (11.7:1), hydro assist steering, hydro boost brakes, belly up, Corbeau CR1 w/5pt harness.
bradentaala is offline
post #2 of 3 Old 06-19-2013, 11:53 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Either way you go its going to be a great combo! I think you have to look at the downfalls of each option With the auto you have to worry about heat but the way you build stuff I can see you adding a cooler with fan so you'll be good on that aspect. . Autos are easier to wheel with IMO . The Sm would be insane in Ta'ala 2 with the. Granny gear. And your current gearing / atlas 4speed. You'll definitely twist axle and driveshafts in 2
Sent from AutoGuide.com App
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 3 Old 06-23-2013, 10:06 AM
90lsturbo
lol wait so your long trusted 4.0 is ready to die? i remember a convo we had a while back how you put it... "oh it will never have a v8" hahaha go th400 with a cooler
2006 dodge ram hemi -DD
1993 zj-sold
1981 cj5- traded
1984 cj7- the other mistress
#89 UJC
"Real men dont let their friends drive prius's"
90lsturbo is offline
