Rear Main Seal - JeepForum.com
post #1 of 16 Old 07-27-2013, 10:11 PM Thread Starter
jeepinbassist
Rear Main Seal
Anyone know of a good shop to get a rear main seal done for a good price?
jeepinbassist is offline
post #2 of 16 Old 07-28-2013, 09:38 AM
Mickey_D
Not sure if you want to try it yourself, but there's always Wrench It Center...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 16 Old 07-29-2013, 08:45 AM
Jeeples
Jeeples's Avatar
Its a two piece RMS (rear main seal) on your 4.0. Its not terribly difficult to do, the hardest part is dropping the pan, but if you let the front axle hang down (assuming you're not lifted) you should have plenty of room.
A quality oil pan gasket, such at the Fel-Pro Perma-Dry series and teflon/PTFE RMS (also available through Fel-Pro), plus oil change supplies means you should be able to DIY for $100 or less. Depending on how competent you are with a wrench, it should take you 4 hours or less. Most shops would probably quote you in the $400+ range to have this done.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #4 of 16 Old 07-29-2013, 04:20 PM Thread Starter
jeepinbassist
I did it, it costed about $50 for the seal the gasket oil and a filter. But I don't think I seated the lower half of the gasket all the way because it's still a bit leaky so I'm going to redo it later.
post #5 of 16 Old 07-29-2013, 10:41 PM
Jeeples
Jeeples's Avatar
I like to offset the seal against the rear main cap. It usually helps keep some of the leaking at bay.
Jeeples is offline
post #6 of 16 Old 07-29-2013, 10:45 PM Thread Starter
jeepinbassist
How do you do that?
post #7 of 16 Old 07-30-2013, 10:08 AM
Jeeples
Jeeples's Avatar
Rather then lining up the seal to sit flat with the main cap, offset it by about a 1/4", so one side of the RMS will sit above the main cap when you install it. Obviously you will need to do the same with other half of the seal as well.
Jeeples is offline
post #8 of 16 Old 07-30-2013, 01:11 PM Thread Starter
jeepinbassist
Oh I see
post #9 of 16 Old 07-31-2013, 12:52 PM
85IrocZ-28
I have never had to do this (except when rebuilding an engine), but I like hearing tips like this!
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #10 of 16 Old 08-01-2013, 08:55 AM
Jeeples
Jeeples's Avatar
I've only had to replace a couple of two piece RMS', but it was a tip that got passed on to me at that time. The idea being that you're offsetting the halves of the main cap and the RMS, making it a little more difficult for oil to seep past them.
Both of the two piece RMS' I did this way didn't have any issues with leaking.
Jeeples is offline
post #11 of 16 Old 08-01-2013, 11:08 AM
85IrocZ-28
It makes perfect sense, I just hadn't ever thought of that.
post #12 of 16 Old 08-01-2013, 01:31 PM Thread Starter
jeepinbassist
But the upper seal on the 4.0 is different than the lower seal.
post #13 of 16 Old 08-05-2013, 04:56 AM
TJDukit
2009 JK Wrangler
Just dab a little RTV on the ends of the RMS and bearing cap and it won't leak.
I.Y.A.A.Y.A.S.
TJDukit is offline
post #14 of 16 Old 08-05-2013, 07:17 PM Thread Starter
jeepinbassist
I tried it again this time I cleaned the bearing cap really well put rtv everywhere it said to. It didn't leak till it gets near operating temperature and then it starts to leak.
post #15 of 16 Old 08-06-2013, 08:59 AM
Jeeples
Jeeples's Avatar
You're positive it's the RMS that's leaking? I know that on the 4.0's the valve cover gasket can leak near the back and run down the back side of the block, making it look like the RMS is leaking. When was the last time the VC gasket was changed and what type of gasket is it (rubber or cork)?
Jeeples is offline
