I've scored a full set if JK brake lines. 4 of them.
2 of them are probably 22inches, 2 shorter ones I assume are for the rear. From my eyeball test, they look the same as the XJ ones on both end in the front. I wonder if anyone had attempted using JK lines in XJ as front extension? (Of course they won't fit the center one in the rear. ) Or is it too long for XJ.
(Feel the necessity to add that I know YJ will bolt on and I'm trying not spend extra cash on them)
Also, I'm on 32s with 3 inch lift. IT's time for the extended bumpstop.
I looked through some brand and sites. While they all look ok with good reviews. But I have no idea how long are they or what lift are they suppose to cover. I assume I need 1 inch longer. Can someone gimme a part number of bunpstops they used on a 3 inch lift.?
I posted in the main XJ forum, but no response for these.
