Northern UT machine shops.. - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > Utah Jeep Forum > Northern UT machine shops..
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineVIAIR compressors at ROCKRIDGE4WD!! DEALS INSIDE!50" LED CREE Light Bar Pair With Wiring Kit
Unread 03-23-2015, 10:39 AM   #1
TmasCJ5
1977 CJ5
I'm building a 360 for my 77 cj5. I have it torn down and the block/heads loaded into my truck to drop at the shop. I was going to use Horsepower Farms, they are here in Cache Valley, just west of Logan... I've heard some good stuff about them and it sounds like they are the only reputable machine shop in the Valley here.
I as wondering before I drop this off if there is a really reputable shop that understands AMC engines, north of SLC? This is my first complete rebuild so I don't want a shop taking advantage of my knowledge shortcomings and I want a shop that is going to help me do the ground work for a long lasting nicely tuned engine.
Thanks for any advice.
TmasCJ5 is offline   Reply With Quote Quick reply to this message
Unread 03-24-2015, 04:55 PM   #2
amp713
Registered Whiskey Killer
amp713's Avatar
You will get a bit better response on the facebook group if you have FB look for the utah jeepcrew community group. Its always busy!
I like my YJ how I like my whiskey, on the rocks with just a touch of color!
SourMash The YJ
F12 MOAB!
amp713 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 01:34 PM   #3
youngjeepr
I use L&R machine in Layton. they did the work on the 360 I built and also the 4.7 stroker that im building. They did great work and are real nice guys. But I believe most of the motors they build are for marine engines.
[COLOR="Red"][/COLOR][SIZE="5"][/SIZE]88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
[URL="http://www.jeepforum.com/forum/f319/"][SIZE="4"][COLOR="Red"][CENTER][B]Utah Jeep Crew[/B][/CENTER][/COLOR][/SIZE][/URL]
[URL="http://www.jeepforum.com/forum/f22/youngjeeprs-build-take-2-a-2012985/"][COLOR="Red"][U][B][CENTER][SIZE="4"]Build Thread[/SIZE][/CENTER][/B][/U][/COLOR][/URL]
youngjeepr is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:00 AM   #4
TmasCJ5
1977 CJ5
Right on, thanks. I will join up with Jeepcrew on FB.
