need some pinion seal help guys. - JeepForum.com
post #1 of 5 Old 10-21-2012, 11:29 AM Thread Starter
PowderPusher
1978 CJ5
ok so my pinion seal on my d44 is leaking pretty bad now and i plan on replacing it tomorrow. i have to change the fluid out of the diff anyway so i was going to do it at the same time. my question is. since i have such a big lift on my tj and i cant properly fill my dif without having the axel jacked up to level, can i fill it up to the fill hole and then add more through the pinion area of the dif to kinda top it off? and i want to take my dif cover off to see whats inside. what is best to use to re-seal the diff cover?
PowderPusher is offline
post #2 of 5 Old 10-21-2012, 11:52 AM
cbandit
A lube locker gasket ($23 iirc) is always nice, that way you don't have to clean off rtv when you open up the diff. However rtv silicone works to seal the diff and is cheap.
cbandit is offline
post #3 of 5 Old 10-21-2012, 12:39 PM Thread Starter
PowderPusher
1978 CJ5
cheap is what im going for and i would rather clean the old stuff off and start with a clean mating surface.
can i top the dif off through this opening? since my dif points down way too much.
post #4 of 5 Old 10-21-2012, 12:49 PM
cbandit
You'd use the lube locker in place of rtv, both need a clean mounting surface. You can fill from the fill plug, if overfilled it will spit the excess up the breather line. Even if jacked up your pinion angle will stay relatively the same. So if you really wanted to use the curb to raise your suspension up (since you don't have a jack) you could but it wouldn't make much difference.
cbandit is offline
post #5 of 5 Old 10-21-2012, 12:52 PM Thread Starter
PowderPusher
1978 CJ5
ok. i might take it to my buddies place and see if he will let me use his lift to raise the front end up to level.
