ISO TJ rear D35 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > Utah Jeep Forum > ISO TJ rear D35
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 05-26-2014, 11:14 AM   #1
HtNRun
ISO TJ rear D35
Hey all, searching for a D35 stock out of a TJ. Bad vibe in mine, leading me to believe pinion. Pulled rear drive line, replace u-joints, vibe still there. Pulled rear drive line and drive FWD, no vibe.
Looking for one in local area. Pulled one out of a WJ, swaybar and shock mount different. I'm not up for modding an axle. Also, if anyone has a rear locker (in case I have to rebuild). I would be open to negotiations.
HtNRun is offline   Reply With Quote
Unread 05-26-2014, 11:46 AM   #2
BLACK04WJ
the WJ axle is also wider and a different bolt pattern... just FYI.
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline   Reply With Quote
Unread 05-26-2014, 04:43 PM   #3
GODMODEX
What gears?
just your average TJ on 33's
GODMODEX is offline   Reply With Quote
Unread 05-27-2014, 12:13 AM   #4
HtNRun
Originally Posted by GODMODEX
What gears?
Right now as long as it bolts right in, I'm not worried about gearing... I'll work that later. You have a lead on one?
Unread 05-27-2014, 07:43 AM   #5
GODMODEX
there's a guy selling a set of tj axles with 3.07 gears on ksl, and another selling one with 4.10's and a lockrite I can post the links if you'd like
Unread 05-27-2014, 10:34 AM   #6
HtNRun
Yes please
Unread 05-27-2014, 06:29 PM   #7
Heepin
I'm looking for some too, 4.10 would be great
Heepin is offline   Reply With Quote
