General CrewCHAT! - Page 264 - JeepForum.com
post #3946 of 4052 Old 05-31-2014, 10:58 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Originally Posted by Mr-Talon
Anyone have problems with 97+ xj getting emissions done? Obd connector not working on machine, but works with a scanner?
Mine works fine
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3947 of 4052 Old 06-01-2014, 02:33 PM
Mr-Talon
1993 XJ Cherokee
I got yelled at by county for interrupting the guy. He told me, do this and that. I already did that. He then says guy needs to get the 16 pin connector fixed, and not to send guy to county building. I told guy to go do his errands and come back. He came back and it worked. Yet again county thinks these new machines are still problem free.
UJC Member #146
Mr-Talon is offline
post #3948 of 4052 Old 06-02-2014, 10:09 PM
90lsturbo
Lol I Had quite the conversation with Tammy today about a Corolla and how I should do this to do this and that and blah blah blah hahaha I know how that **** goes it's never-ending with.them
2006 dodge ram hemi -DD
1993 zj-sold
1981 cj5- traded
1984 cj7- the other mistress
#89 UJC
"Real men dont let their friends drive prius's"
90lsturbo is offline
post #3949 of 4052 Old 06-02-2014, 11:12 PM
Mr-Talon
1993 XJ Cherokee
Tammy a beeyotch. Today at work we got the torch, cherry picker and started to take the in ground dyno out. Also got a tire balancer. Next week we will get a tire machine, and start doing tires at my work. Yippi, I hate tires.
UJC Member #146
Mr-Talon is offline
post #3950 of 4052 Old 06-03-2014, 11:34 AM
90lsturbo
No **** lol
1993 zj-sold
1981 cj5- traded
#89 UJC
post #3951 of 4052 Old 06-04-2014, 08:14 PM
Modstock
Its not bad when its your own tires though. Id perfer doing my own cause there are some idiots out there .
Modstock is offline
post #3952 of 4052 Old 06-17-2014, 11:56 PM
Mr-Talon
1993 XJ Cherokee
Since I'm the jeep guy at my work I got stuck trying to help a customer fix his 2000 wj problems. #1 96 zj motor, #2 motor mounts been chopped and 1 bolt holding the brackets in, rubber mounts are destroyed. #3 wrong ex manifold so leaks really bad, and I can see into the head in all 6 cyl. #4 ex pipe after the cat converters is resting on the front driveline. Alot of lights on in the dash, grinds when starting, runs really rough. Any thoughts on making this work? I already told him to put correct motor in it, sell it. No go there. He kept asking me over and over the grind the converter flange so it won't rub on mount. Now he wants me to weld some motor mount brackets onto his frame. It's ghetto and poorly put together. Ahhhhhh
UJC Member #146
Mr-Talon is offline
post #3953 of 4052 Old 06-18-2014, 12:50 AM Thread Starter
311LJ
311Popo
311LJ's Avatar
I'd turn them away. You Don't Have To Fix every Vehicle that comes in. To much liability with him finding things wrong down the road and your shop eating it.
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #3954 of 4052 Old 06-18-2014, 07:51 PM
Modstock
Isnt that engine swap not-legal anyways ?
I thought it had to be the same year (motor/body) on newer cars from 1986 on if I remember correctly .
Id send him packin .
Modstock is offline
post #3955 of 4052 Old 06-18-2014, 09:28 PM
Mr-Talon
1993 XJ Cherokee
It has to be a motor that was offered in the particular vehicle, Then it has to be same year or newer then vehicle. I tried to tell him to call it quits but wouldn't listen. Said it took him 13 days to do it and he is not a quitter.
UJC Member #146
Mr-Talon is offline
post #3956 of 4052 Old 06-19-2014, 08:30 AM
Mickey_D
Then tell him he ain't done yet. He got this far he can continue.
Tell him straight out you are a Jeep fixer - not a bloody miracle worker. You can only fix things that were originally done right due to liability.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3957 of 4052 Old 06-19-2014, 11:37 PM
Mr-Talon
1993 XJ Cherokee
Lol, he didn't show up today. oh well.
UJC Member #146
Mr-Talon is offline
post #3958 of 4052 Old 08-02-2014, 12:28 AM
skullysXJ
any WJ guys have a stock t case skid they want to part with for cheap???
~KADE~ kool kid klub #1
08 JKU Rubicon
skullysXJ is offline
post #3959 of 4052 Old 08-05-2014, 11:27 AM
Godholio
Not for a Jeep, but does anybody know a reliable shop that knows old cars and doesn't charge an arm, leg, and firstborn? I've got a '66 SBC that's got an uncooperative idle (won't run well below 1000 rpm) and doesn't pull enough vacuum. I don't know if the two are related, but I assume so. Once I get the carb back from a rebuilder, I've got exactly one more idea and then I'm completely stumped and will probably take it somewhere.
Preferably in Weber, Davis, or SL Counties.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #3960 of 4052 Old 08-05-2014, 12:54 PM
youngjeepr
Originally Posted by Godholio
Not for a Jeep, but does anybody know a reliable shop that knows old cars and doesn't charge an arm, leg, and firstborn? I've got a '66 SBC that's got an uncooperative idle (won't run well below 1000 rpm) and doesn't pull enough vacuum. I don't know if the two are related, but I assume so. Once I get the carb back from a rebuilder, I've got exactly one more idea and then I'm completely stumped and will probably take it somewhere. Preferably in Weber, Davis, or SL Counties.
How big is the cam? And what is the timing set at?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
