Front drive shaft after lifting the JK 4" - JeepForum.com
post #1 of 23 Old 03-15-2013, 03:52 PM Thread Starter
Marhey
2017 JK Wrangler
So, it appears that my front drive shaft and my transmission have been fighting. I assume this means I need a new aftermarket front drive shaft that is thinner so it won't rub. At least that's on another forum, but I prefer to run it by the awesomeness here first. Thoughts on what to get or do?
TIA!
Marcus | UJC #158 | 2017 JKUR
Marhey is offline
post #2 of 23 Old 03-15-2013, 03:53 PM Thread Starter
Marhey
2017 JK Wrangler
Holy huge images Batman! (attempting to edit now...)
I failed. Cannot edit super-huge images after uploading...
Marhey is offline
post #3 of 23 Old 03-15-2013, 04:59 PM
team1k
So its just rubbing on that lip and bent it a little? Looks like its already self clearanced to me and i wouldnt worry about it. maybe pound the lip a little flatter with a hammer
It was a Jeep thing, but all that stuff broke
92 Jeep YJ Wrangler
UJC
"YJ's are for poor people" - Brian
team1k is offline
post #4 of 23 Old 03-15-2013, 05:01 PM Thread Starter
Marhey
2017 JK Wrangler
Thanks. The boot is also torn though. Will the joint (u-bolt or whatever) wear out now?
Marhey is offline
post #5 of 23 Old 03-15-2013, 07:08 PM
team1k
Maybe one of the JK guys will chime in who know but I assume that under the boot is just the splines that slip in and out. On mine those are already exposed and I don't have issues so I wouldn't think it's a big deal.
92 Jeep YJ Wrangler
UJC
team1k is offline
post #6 of 23 Old 03-15-2013, 07:15 PM Thread Starter
Marhey
2017 JK Wrangler
I will examine further and report back if I can get some better pictures.
Marhey is offline
post #7 of 23 Old 03-15-2013, 07:59 PM
plrbear
Must be a 4 door. I don't think those drive lines have splines that slip. Their more like a cv type, I'd have one built before doing much serious wheeling. As for the clearance I've installed lifts on a couple we had drive lines built then trimmed the cross member for clearance.
ITS ALL FUN AND GAMES TILL SOMEONE GETS HURT..... THEN ITS HILARIOUS!!!
2008 2dr JK Mostly stock...
Utah Jeep Crew #09
plrbear is offline
post #8 of 23 Old 03-15-2013, 08:18 PM Thread Starter
Marhey
2017 JK Wrangler
Yes, it's a 4-door. "Have one built"? Like from 6 States?
Marhey is offline
post #9 of 23 Old 03-15-2013, 11:16 PM
plrbear
Yes, we've done a couple and they have both needed different length shafts. Jason at six states in Orem does great work.
Utah Jeep Crew #09
plrbear is offline
post #10 of 23 Old 03-15-2013, 11:24 PM
kellerexpress
This is a common problem for 4 door JK's lifted 4" and up. Yes the stock drive shaft has a CV joint under that boot. If the tear is bad enough to let dirt/water into the joint it will eventually fail. No grease = eventual failure. Unfortunately the boot cannot be replaced. You will be OK for a bit but keep a close eye on it. For peace of mind I would replace it. At 4" of lift you will eventually need to get a new aftermarket front driveshaft anyway. Sucks.
kellerexpress is offline
post #11 of 23 Old 03-16-2013, 12:08 AM Thread Starter
Marhey
2017 JK Wrangler
Thanks for the info guys. Maybe I can put a new on one when I replace my front diff.
Marhey is offline
post #12 of 23 Old 03-16-2013, 01:54 AM
Mickey_D
Price out Gaylon's in American Fork before committing to Six States. 6S wanted $75 to start for shortening my front shaft. Gaylon's did it for $55. Plus they painted it for me.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #13 of 23 Old 03-18-2013, 10:41 AM
311LJ
311Popo
311LJ's Avatar
Yup, Gaylons did an awesome job shortening my front drive shaft. got it back all painted and he gave me an extra set of straps to keep in my rig.
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #14 of 23 Old 03-18-2013, 10:58 AM Thread Starter
Marhey
2017 JK Wrangler
Thanks guys. I just wish there was a decent 4x4 shop in the SL Valley...
Marhey is offline
post #15 of 23 Old 03-18-2013, 12:56 PM
Mickey_D
Oh, there probably is. But I don't like crossing Point of the Mountain unless I have to...
________________
#4
Mickey_D is offline
