Coolant Goblins - JeepForum.com
post #1 of 13 Old 02-03-2013, 11:43 PM Thread Starter
Tblack
Coolant Goblins
I was parked idling today outside my girlfriends house waiting to drive to layton for the superbowl party. While waiting my gauges beeped and I thought to myself, "I'm not low on gas" and saw the needle buried into the red on my temp gauge. OH CRAP! I gave the engine some gas and the needle SLOWLY came down to operating temperature.
I parked the jeep and took the car. When I got home I noticed the overflow bottle was empty, pulled the cap and the radiator was dry. It took a little over a gallon to fill it back up. I flushed and filled the system in august and have had zero problems with coolant consumption. There is no leaks in my garage, no leaks on my carpet, no coolant in the oil and no evidence of a blown head gasket.
So, where could this stuff be going???
Safety 3rd!
Tblack is offline
post #2 of 13 Old 02-04-2013, 12:48 AM
Mickey_D
Do a compression test. I pray for you that all 6 are the same.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 13 Old 02-04-2013, 03:46 AM
kellerexpress
Climbed any steeps hills lately that could have caused some coolant to spill from the overflow? Whenever I climb something really steep in my Jk I notice a bit of coolant leaking from the reservoir.
kellerexpress is offline
post #4 of 13 Old 02-04-2013, 07:39 AM Thread Starter
Tblack
Im not sure what the reservior is like in the JK, but the TJ has a really deep bottle where the coolant would struggle to work its way out.
I just got to work so I will let the engine cool down and then I will check the dip stick first and see if there is any sign of the coolant in the oil. Then I will go from there. From a power stand point, there is not noticeable difference that could indicate crappy compression. Definitely not enough to missfire.
Safety 3rd!
Tblack is offline
post #5 of 13 Old 02-04-2013, 12:48 PM
Mickey_D
It doesn't take much of a blown head gasket (we're talking single digit thousandths of an inch) to overpressurize the cooling system and blow all the coolant out.
Had it happen before. It's rare, but it does happen. Especially if yours has the infamous 0331 head.
________________
#4
Mickey_D is offline
post #6 of 13 Old 02-04-2013, 01:50 PM Thread Starter
Tblack
I just checked the oil again in daylight, the oil is right on the money and has no visible signs of coolant. No smell and it doesnt feel like it when you rub it between your fingers. I had to add a couple dixie cups of water to the system I would assume it was just from the system burping itself on the drive in to work thismorning.
My only real concern is the potential damage that may have been done when it overheated. Everything seems absolutely normal though, so I may have gotten lucky.
Safety 3rd!
Tblack is offline
post #7 of 13 Old 02-04-2013, 06:08 PM
Mickey_D
The 4.0 can handle quite a bit of punishment without any trouble. Just ask my old XJ. I cooked that thing dry 5 times in a row. Even had to drive 3 miles on the freeway with it blowing steam and it still ran fine when I sold it.
So long as it doesn't have the 0331 head on it.
________________
#4
Mickey_D is offline
post #8 of 13 Old 02-05-2013, 08:21 PM
Godholio
It doesn't sound like you were overheating anywhere near long enough to do anything major. If that coolant burned off in your cylinders you probably have some f-ed up pistons...but it doesn't sound like that happened either. I think a compression test is definitely the next step. If that comes back ok, I'm stumped. I'd probably start checking hose tightness and see if maybe a leak develops under pressure. Maybe replace the cap.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #9 of 13 Old 02-05-2013, 08:56 PM Thread Starter
Tblack
I replaced the cap when I did the coolant flush. I am wondering if being winter may have something to do with it. I used to have the issues with the intake manifold leaking when the engine was really cold and then stopped when the engine warmed up. I snugged down the Intake manifold and it went away. Is there a possibility that this could be a similar problem where the coolant will seep into other parts of the engine and get burned off when the engine is cold?
I am only taking insane shots in the dark here because I am running out of options short of just driving it normally, checking the coolant and seeing what happens. Maybe this weekend I will get the chance to do my compression test.
Safety 3rd!
Tblack is offline
post #10 of 13 Old 02-05-2013, 09:22 PM
youngjeepr
I would do a pressure test on your coolant system... That will tell you if there is a leak and if it's a small leak that only leaks while under pressure you'll be able to see/hear it.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #11 of 13 Old 02-05-2013, 09:26 PM
team1k
On my YJ i had a small leak on the bottom of my thermostat housing. When it first started up a bit of coolant would leak out and onto the block for the first few minutes of driving. It was un-noticable for months since it would just burn off once the block got hot, and there would never be a pool under the jeep. I just kept adding fluid knowing the problem would get worse and then i would find out what it was. Eventually the leak got worse and i started to smell the antifreeze while driving so i was able to locate the leak. My guess is something similar is happening either at the thermostat, waterpump, or one of the hose fittings.
It was a Jeep thing, but all that stuff broke
92 Jeep YJ Wrangler
UJC
"YJ's are for poor people" - Brian
team1k is offline
post #12 of 13 Old 02-12-2013, 09:57 PM
cbandit
I loose coolant out of my reservoir while off-roading also... look at your water pump to see if it's weaping. My pump did so un-noticed because its such a small amount that it usually won't leave a puddle or anything. I finally noticed when it sounded like I got a rod knock one day from the bearing on the pump. best of luck!
BUILD THREAD - http://www.jeepforum.com/forum/f22/cbandits-build-1472103/#post14888528
cbandit is offline
post #13 of 13 Old 02-12-2013, 10:02 PM
cbandit
also make sure you bleed the coolant system if adding a decent amount of coolant, an air bubble could cause a blockage in the system.
cbandit is offline
