Anywhere local (or anyone in the crew) that would weld 8.8 swap brackets? - JeepForum.com
post #1 of 9 Old 12-01-2013, 11:52 PM Thread Starter
GODMODEX
Tj Anywhere local (or anyone in the crew) that would weld 8.8 swap brackets?
Alright long story short, I will be picking up a TJ soon. I really want to find one with a d44 to save myself the hassle and $ of and axle swap, but I'm not planning on it, because it seems unlikely from the few I've looked at. I've looked at ECGS's bolt in solution and it looks like a good bet, my problem is that I do not have a welder, or welding skills. It would be cheaper to get a JY 8.8, and a bracket kit, and get it welded on. So anyone know of somewhere, or someone in the Utah Jeep Crew that could weld brackets on for me, assuming I brought the axle ready for work, or anyone have an estimate of what it would cost? I'm just trying to plan out my build, and decide what I really want to do for it.
I'm almost to the point where I would stick it on 32's, keep stock gearing and a d35, and call it good just pricing out my build with an axle swap
01 TJ, 32RH, 4.0, 8.8, hpd30, 35's, metalcloaks
07 CBR600RR, full Akra exhaust, PC V, etc.
GODMODEX is offline
post #2 of 9 Old 12-11-2013, 10:16 AM
mbryson
1980 CJ7
Good guy that posts quite a bit on RME4x4.com that's down by you. Seems to do good work from what I can see.
Unlimited Fabrication, LLC
1096N 450W Unit 108
Springville, UT 84663
801-918-1737
www.marbryson.com
mbryson is offline
post #3 of 9 Old 12-11-2013, 10:22 AM
BLACK04WJ
X2 on unlimited fabrication!! the guys name is mitch is he does amazing work. Im sure I look like a little kid on christmas morning every time I go in his shop haha. He can and will set you up right man. only downfall.. he does such amazing work that he is booked several weeks out with other customers axle builds. I doubt you would be in a huge hurry so it probably wont be a problem. I would recommend Unlimited Fab for anything axle related.
and PS.. stop looking around for a jeep and just buy my TJ
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #4 of 9 Old 12-15-2013, 08:03 PM
Tuffjeeper
A friend of mine, also in Springville did the welding of the housing to the tubes etc for me. Check out Regulator Racing on FB, he has pics of his work on my axle.. I would recommend him if Unlimited Fabrication is backlogged, etc.
Tuffjeeper is offline
post #5 of 9 Old 12-20-2013, 01:43 PM
morty00
1096N 450W Unit 108
801-918-1737
x2
morty00 is offline
post #6 of 9 Old 12-20-2013, 01:58 PM
98GAXJ
You can always DD the Dana 35 until you have the 8.8 ready.
I wheeled a TJ with a Dana 35 on 35's at Tellico. As long as you are smart,& don't hammer it, you should be fine.
98GAXJ is offline
post #7 of 9 Old 12-21-2013, 09:03 PM
Tuffjeeper
Originally Posted by 98GAXJ
You can always DD the Dana 35 until you have the 8.8 ready. I wheeled a TJ with a Dana 35 on 35's at Tellico. As long as you are smart,& don't hammer it, you should be fine.
X2. If you treat it as a 35 and not a 14 bolt you should be fine to wheel it til you get a replacement axle built.
Originally Posted by plrbear View Post
Destroyed it somehow..... It went wobble wobble wobble boom
post #8 of 9 Old 12-22-2013, 04:29 PM
311LJ
311Popo
311LJ's Avatar
x2, my brother in law does good work. he also welded the axle cradle on my WJ rear axle for the 4 link.. He will be willing to do it quick and clean but will require it out from under the jeep.. when you reach a certain level of welder and your day job is an engineer you can make those kind of requests lol
John
04 TJ Unlimited, GenRight Armor, 37's
89 XJ Laredo, 31's
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY*
I ♡ John
311LJ is offline
post #9 of 9 Old 01-08-2014, 12:35 PM Thread Starter
GODMODEX
Thanks for the info guys. I decided to save up a little longer, and just get a 2 dr JK. I am going to have to put just as much of a down payment on a TJ, and my interest rate will be higher (my bank wants a 04 or newer, so a LJ or a TJ rubicon is still in the picture) I just don't want to pick something up that is going to need an axle swap, and already has 120k miles on it. I'm thinkin a low milage 07-08 2 dr JK now, or a LJ, or I'm gonna find a bank that'll give me a better loan on an older TJ.. It'll probably be closer to summer if it does happen, and I'm leaning more towards a JK at this point, just for the fact that they're newer and nicer, and I can find a lower milage one.
GODMODEX is offline
