07 JK can't get my front lockers to engage? - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > Utah Jeep Forum > 07 JK can't get my front lockers to engage?
Unread 06-19-2013, 03:25 PM   #1
ralph_801
Taking lunch today at work I was messing around in a lot near by, I couldn't get the front lockers to lock? any ideas?
ralph_801 is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 03:39 PM   #2
ralph_801
and am i correct in assuming i need to be in 4 l0 for the lockers to be usable? i know rookie questions, i'm still new to the game and trying to learn as much as i can
Unread 06-19-2013, 03:41 PM   #3
kellerexpress
Yes you can only engage the lockers in 4-LO.
kellerexpress is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 03:42 PM   #4
ralph_801
the sway bar will disconnect, the rear lockers will fully engage but my dash light for front lockers just blinks and blinks and blinks then laughs at me and then continues to blink
Unread 06-19-2013, 03:48 PM   #5
kellerexpress
When it blinks are you moving the jeep of just sitting still?
Unread 06-19-2013, 03:51 PM   #6
ralph_801
both, i started just sitting still then puttered around 2-3mph and still nothing should i try locking before disconnecting the sway bar? or would that not make a difference
Unread 06-19-2013, 03:54 PM   #7
kellerexpress
I see....I was asking because I have to be moving some to get mine to engage/disengage. The sway bar wont make a difference. Is this the first time you have attempted to use the lockers?
Unread 06-19-2013, 03:55 PM   #8
ralph_801
i used the rear when we went to mineral basin i didn't try to engage the front. i will try it again after work moving a little faster and see if that helps? i'm gonna be PISSED if it's something serious that is wrong
Unread 06-19-2013, 04:16 PM   #9
kellerexpress
check the plug on top of your front axle that powers the locker. You can also check your fuse and I believe there is are relays under the hood you can check as well. They are located just to the left of the battery.
Unread 06-19-2013, 04:19 PM   #10
ralph_801
alright cool i'll do that when i get home! hopefully it'll be a simple fix!!!
Unread 06-19-2013, 07:54 PM   #11
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
What's a swaybar I don't have those on my Xj or Yj
Sent from AutoGuide.com App
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is online now   Reply With Quote Quick reply to this message
Unread 06-19-2013, 08:00 PM   #12
Mickey_D
My 55 Willys didn't even have the possibility of them!!
My ZJ has them front and rear - not that they do anything. The Orvis rolls in corners WORSE than the Willys did...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 08:27 PM   #13
Tom95YJ
Tom95YJ's Avatar
That is because coils give that plush ride for sissys lol
Unread 06-19-2013, 11:04 PM   #14
Mickey_D
Hey, you're half way there...
________________
Unread 06-19-2013, 11:33 PM   #15
YJYNOTJ
I assume ur talkin a rubicon? Mines an 03 so slightly different, but when I first got it I tried the lockers in a parking lot didn't seem to be working. Seems to me they fully engage easier on at least dirt road where the tire can slip a little. Also the front seems to blink a lot no matter what, but I can tell its full locked.
2003 TJ Rubicon
93 Wrangler YJ (Sold)
08 Liberty KK – 245/75R16 | 3.5 front 2.5 rear RockKrawler Lift
YJYNOTJ is offline   Reply With Quote Quick reply to this message
