Who had the speedo gear issue? - JeepForum.com
post #1 of 5 Old 10-17-2013, 11:25 AM Thread Starter
Vegas 4x4
Did you resolve it? I just found this. Kinda hard to see in the pic, but the gear is grooved where is seats against the housing, and the little circles are melted gear material that I scraped off the tip of the housing.
Vegas 4x4 is offline
post #2 of 5 Old 10-17-2013, 11:34 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Larry,
I believe it was Powrjunky
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #3 of 5 Old 10-17-2013, 11:38 AM Thread Starter
Vegas 4x4
Larry,
Thanks, I hope he sees this thread. I just discovered this one was clocked incorrectly, so perhaps his is too. I'm surprised this one worked
post #4 of 5 Old 10-22-2013, 04:01 PM
Powrjunkey
Powrjunkey's Avatar
I'm fairly certain I'm getting it clocked/indexed correctly. The tooth range of the gear on the housing is to be pointed at the 5 o'clock position, correct? I'll quintuple check it again tomorrow morning before work.
Powrjunkey is offline
post #5 of 5 Old 11-11-2013, 11:38 AM Thread Starter
Vegas 4x4
Here's more info - The Rugged Ridge SYE Kit may be your problem. The gear is mashed into the drive assembly on the RR product, and the Advance Adapter product has some end float to prevent this from happening. If you have a Rugged Ridge SYE kit, pull the speedometer drive and look at where the end of the speedo gear would contact the tail-housing. You'll likely see marks where the speedo gear has gouged it. Here's a couple of pics.
