Trail Run Thread - Southern Nevada - Page 53 - JeepForum.com
post #781 of 1355 Old 07-26-2013, 08:40 AM
sirhk100
Tentative plan for rocky gap(potato) on Saturday. Meet at Mcds/Starbucks at 10k block west charleston at 9ish to Leave at 930ish? Brining the babies, so it will be slow going, with multiple stops, just fair warning. My wife hasn't been all the way through, so she's going to want to stop and look at stuff along the way. I also want to get some good Jeep footage and pics also. I'm going to figure on a return to vegas time at around 4-5pm. Would really like at least one other rig along just in case of breakage/malfunctions in equipment. By then, I'll have brake lines and everything done so I'll want to really see what this beast is capable of, within safe reason!
Is this still the plan?
https://maps.google.com/maps?q=las+v...61865&t=h&z=20
Khris
sirhk100 is offline
post #782 of 1355 Old 07-26-2013, 08:58 AM
B0nez
If I can get some wrenching time in tonight or tomorrow AM, I might show up for this run.
What time do you guys plan on being at the Lovell Canyon trail head? I would rather meet you guys there since I drive slower than you guys.
Not that I really care, but I am curious why are you meeting at a random McDonalds instead of the standard meetup spot for this trail (Gas Station @ the corner of SR 159 - Red Rock Canyon Road and SR 160 - Blue Diamond Road)? https://maps.google.com/maps?q=89148...89148&t=h&z=17
B0nez is online now
post #783 of 1355 Old 07-26-2013, 09:02 AM
Garza
Vendor
Garza's Avatar
Originally Posted by sirhk100 View Post
My guess is unless Power wants to wheel with 3 shocks, he may be out One of the shocks I got him leaks at the crimp on the reservoir hose.
Garza is offline
post #784 of 1355 Old 07-26-2013, 09:08 AM
sirhk100
Bonez, I drive like a grandma myself as well. And no clue on the meeting stuff... I'm just going where told.
Garza/Power... I'm 99.9% sure I've got a hose off a bilstein laying around. Not sure if the size/threads are the same though. I can get a measurement this afternoon when I get home and if they seem like they're the same we could always try swapping hoses really quick. Should only take 15-20 minutes or so to tear one down, swap hoses and reassemble... Or take the hose to a hose place today ( http://www.allhoseinc.net/ ) and see if they can re-crimp it real quick for cheap.
Khris
sirhk100 is offline
post #785 of 1355 Old 07-26-2013, 09:17 AM
Garza
Vendor
Garza's Avatar
Garza/Power... I'm 99.9% sure I've got a hose off a bilstein laying around. Not sure if the size/threads are the same though. I can get a measurement this afternoon when I get home and if they seem like they're the same we could always try swapping hoses really quick. Should only take 15-20 minutes or so to tear one down, swap hoses and reassemble... Or take the hose to a hose place today and see if they can re-crimp it real quick for cheap.
I don't even think it requires a tear down does it?......bleed the nitrogen off, swap the hoses (saving as much oil as you can), then recharge?? I'm hoping what was a leaky fitting that he tightened turns out to be residual on the hose, but I don't think we'll be that lucky.
AND with Power's OCD, I don't think he could stand to have a Bilstein hose on a Fox shock
I'm at all-hose now getting steering parts for the buggy!!
Garza is offline
post #786 of 1355 Old 07-26-2013, 09:26 AM
sirhk100
I'm not sure how you'd bleed all the air out thru the resivoir though? I'm not saying it's impossible, I just don't know how to do it... If I've got a shock body in one hand and the resi in the other. I can thread the hose into the body, fill it to the tippy top with oil. Now how to I fill the resi and thread it on without loosing oil? Say you pull the resi apart, knock the deviding piston out. Fill it there, how do you get the piston back in without trapping oil?
Like I said, maybe there's a way, I just have never done it and don't know how...
Hardest part is likely going to be getting the resi hose loose on the resi cap and the shock body. They use like mega super ultra retard strength loctite usually.
I see it as replace the hose, pop the cap on the shock, pull the shaft out, top it off with fluid, slide it back in and pop the bottom back on since I don't know of another way.
And yeah, I agree, power probably wouldn't be able to handle a blue hose on his shocks.
Khris
sirhk100 is offline
post #787 of 1355 Old 07-26-2013, 09:49 AM
Garza
Vendor
Garza's Avatar
Just a thought, but what about bleeding off the nitrogen, leaving the hose in place and seeing if it can be re-crimped on the shock and then re-charged? I know that is dependent upon the crimp tool, but in theory??
Garza is offline
post #788 of 1355 Old 07-26-2013, 10:03 AM
sirhk100
Absolutely if they can do that, it's 100% the way to go!!! If you guys need nitrogen I have a bottle...
Khris
sirhk100 is offline
post #789 of 1355 Old 07-26-2013, 01:47 PM
Powrjunkey
Whelp, it looks like I'm out for the saturday run! Not cool! I'll be trying to organize another run in the next couple weeks, if possible.
Powrjunkey is offline
post #790 of 1355 Old 07-26-2013, 01:49 PM
sirhk100
So... Then is anything going on tomorrow? If not, no biggie, it'll just allow me to be lazy tonight instead! LOL
Khris
sirhk100 is offline
post #791 of 1355 Old 07-26-2013, 02:01 PM
Puck81
I am still going. Probly in the late afternoon. I want to try out the 35's.
Puck81 is offline
post #792 of 1355 Old 07-26-2013, 02:05 PM
sirhk100
What time you thinking? I have plans tomorrow evening so I need to be back in town at a reasonable time. I'm also down for somewhere else but the temps are probably a bit more then I want to subject my DD too honestly.
Khris
sirhk100 is offline
post #793 of 1355 Old 07-26-2013, 02:10 PM
sirhk100
You know that's probably like a $5-10 fix if you walk into all hose with it right? Worse case have them knock out a whole hose for you, drop the shock and hose off at my house tonight during your route and pick it back up like 30 minutes later or anytime after finished and ready to go. No excuse man, step up and get it done!!!!
Khris
sirhk100 is offline
post #794 of 1355 Old 07-26-2013, 02:21 PM
Garza
Vendor
Garza's Avatar
We're working on it now.....cross your fingers that it was just some residual in the weave of the braided hose!!
Garza is offline
post #795 of 1355 Old 07-26-2013, 02:23 PM
matthew900
I was still planning to go in the morning. Is anyone else still planning to go then?
matthew900 is offline
Chat - The Official Las Vegas/Southern Nevada Chat Thread Dr. Marneaus Nevada Jeep Forum 41803 Today 02:49 PM
Nevada Jeeps Rickyb Nevada Jeep Forum 1 10-18-2009 07:35 PM
Elko, Nevada anyone? bernie Nevada Jeep Forum 3 08-09-2008 05:57 PM
Need Nevada Trails timatoe Nevada Jeep Forum 2 02-17-2008 03:38 PM
