Need an Axle Shaft - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > Nevada Jeep Forum > Need an Axle Shaft
Bill Baird Motorsports DIY parts - NalinMFG.comFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 06-03-2014, 02:51 PM   #1
srl520
Need an Axle Shaft
Anyone know of any used 27 spline axle shaft passenger side for 94 wrangler?
srl520 is offline   Reply With Quote
Unread 06-03-2014, 04:17 PM   #2
matthew900
matthew900's Avatar
If it's a front shaft you should be able to find a compatible one on an XJ at the pic a part.
matthew900 is offline   Reply With Quote
Unread 06-03-2014, 06:06 PM   #3
Vegas 4x4
If you want to convert it to a one piece shaft, I have a used shaft and the conversion kit in stock.
Vegas 4x4 is offline   Reply With Quote
Unread 06-03-2014, 06:44 PM   #4
srl520
I forgot to add that it is for the rear. I have a 8.8 that I plan on installing this winter so I am not wanting to buy new or spend lots of money. I took it apart yesterday and found the bearing has run dry for some time and has wore into the shaft. I reinstalled axle and add gear lube. I was hoping to find a used shaft to get me buy through the summer.
Unread 06-03-2014, 09:06 PM   #5
Vegas 4x4
Rear what? D35?
Unread 06-03-2014, 10:01 PM   #6
srl520
yes, D35
Unread 06-03-2014, 10:08 PM   #7
Vegas 4x4
I'm not sure if I have a used one, but if you call I'll check for you.
Unread 06-04-2014, 12:52 AM   #8
whalejr31
I have a whole stock drum to drum dana 35 (and a dana 30 minus a knuckle for that matter) sitting in my garage. PM me and we can talk!
whalejr31 is offline   Reply With Quote
Unread 06-10-2014, 06:21 PM   #9
srl520
I was able to locate one.
Thanks
