Las Vegas ZJ's. - Page 2 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > Nevada Jeep Forum > Las Vegas ZJ's.
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-18-2013, 04:42 AM   #16
perfeng702
I used to have a ZJ. Now I have a WJ... Even fewer of those around...
ZJ destroyed when I got nailed by a drunk driver in the airport tunnel.
1999 WJ 4.7, 242HD, IRO 4" Long Arm, IRO Adj Track Bar, JKS BPE, JKS Quick Disco, 15" Cragar D-Window, 32" BFG KM2, V3 Projectors, DDM Tuning 55w 5k HIDs
perfeng702 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2014, 12:27 AM   #17
Zjrookie
Hello everyone I just recently bought a 98 zj limited and doing some work to it currently have 2.25 bb and working on plans for a rack and rock sliders and fixing some of the sloppy crap the previous owner did but I am down to hit some trails cause this has to off road better than my diesel long bed
Zjrookie is offline   Reply With Quote Quick reply to this message
Unread 02-14-2014, 08:59 PM   #18
B0nez
Welcome! Be sure to keep an eye on the Trail Run Thread - Southern Nevada for additional info on up and coming trail runs.
B0nez is offline   Reply With Quote Quick reply to this message
Unread 02-15-2014, 12:38 PM   #19
Puck81
Welcome to the forum. Definitely keep your eyes posted on the trail run section of our forum.
Puck81 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2014, 08:24 PM   #20
Zjrookie
Wondering if anyone has tackled Dana 30 & 44 bearings plus a transfer case swap in the zj
Unread 03-02-2014, 08:49 PM   #21
Grand_ZJ
I've done wheel bearings in the front since its just a hub assembly. The transfer case swap is easy as hell!!
Just remove your old t-case and put the new one in. I put in a 231to replace my tired 249.
What questions do you have specifically?
1996 XJ Sport
Grand_ZJ is online now   Reply With Quote Quick reply to this message
Unread 03-03-2014, 07:44 PM   #22
Zjrookie
How hard are the bearings to do and any particular brand and the t case swap since I am going from 98 to 98 it's a direct swap? Cause they told me it was from a 5.2 at lkq
Unread 03-03-2014, 10:03 PM   #23
ksturgio
there is a long thread on the swap in the zj section for the TC swap. Tons of info and will give a heads up on what to expect. I think it is even a sticky. I believe you are swapping to a 242. I have a zj bezel if you want it.
ksturgio is offline   Reply With Quote Quick reply to this message
Unread 03-03-2014, 10:10 PM   #24
Grand_ZJ
With the tcase you have to make sure that the input shaft is matching give or take. And what kind of tcase are you switching out for the one at lkq???
1996 XJ Sport
Unread 03-04-2014, 08:58 AM   #25
Zjrookie
Yeah read all the swap stuff few have done a direct swap so I feel pretty confident. The tcase I am swapping with lkq is the my 249 for the 242 and I would gladly take the spare bezel from you when you have time.
Unread 03-04-2014, 09:35 AM   #26
Grand_ZJ
What do you mean few have done a direct swap??
1996 XJ Sport
Unread 03-04-2014, 11:17 AM   #27
ksturgio
I think most people grab 242's from xj and the shafts usually don't match.
Unread 03-04-2014, 11:42 AM   #28
Grand_ZJ
I grabbed a 231 from an xj and surprisingly the first one I got matched perfectly.
1996 XJ Sport
Unread 03-04-2014, 12:27 PM   #29
Zjrookie
Most people grab 242 have to do planetary swap but few have pulled a later case and have done a simple swap of just change case and drive shaft. Most post all have split the case and tail shaft swaps which I want to avoid that's why I opted for a later tcase from same year.
Unread 03-04-2014, 12:28 PM   #30
Zjrookie
I am hoping that a 242 out of a 98 zj will plug right into my 98 zj but I will keep you guys posted
