Las Vegas SMOG help - JeepForum.com
post #1 of 8 Old 09-05-2014, 11:02 PM Thread Starter
badtoy1986
Yj Las Vegas SMOG help
I have a 95 YJ with a 5 speed, no AC no PS and the 2.5L 4cyl. I went to get my annual smog check done the other day and I failed due to high CO (Carbon Monoxide) at idle. All of my other numbers were passing. I believe a passing score is >1.2. I was getting ~2. I figured I would be okay, I did a full tune up less than a year ago. Changed spark plugs, wires, cap, rotor and O2 sensor.
After I failed I went and got a fresh oil change(I was due). and I swapped out the air filter. I drove for about and hour and took it back the smog place again without shutting it off. I did better but this time I was just under 2 at idle.
Do you have any suggestions on how I could fix this or where I should go to get it fixed or get some assistance getting it to pass.
Any help is appreciated.
badtoy1986 is offline
post #2 of 8 Old 09-06-2014, 08:23 PM
ksturgio
Bad cat? Just a guess. May also be a bad O2 sensor, sometimes aftermarket ones don't seem to last as long. Maybe clean the throttle body as well. Try and seafoam it.
ksturgio is offline
post #3 of 8 Old 09-07-2014, 06:24 PM Thread Starter
badtoy1986
I replaced the O2 sensor about 11 months ago with a Boch OEM one. I have heard a little about Seafoam, but I am not sure it would fix the problem. I think its just a ritch idle. Maybe a little low idle (750RPM). I'm thinking its an injector not closing all of the way or high fuel pressure. I don't have any tools to check for ether of the those though.
post #4 of 8 Old 09-07-2014, 06:33 PM
repairman
The last time I had a vehicle fail for smog I bought a bottle of "guaranteed to pass" and it worked. It cleans the fuel system and I think makes it run leaner.
repairman is offline
post #5 of 8 Old 09-07-2014, 11:00 PM Thread Starter
badtoy1986
Thanks, ill try that. Did you run a full tank through it first? Do you remember why it failed?
post #6 of 8 Old 09-08-2014, 10:07 AM
jokerchief462
There is a great website out there called smogtips.com
Has all the info on how it all works and some will help troubleshoot your fail
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #7 of 8 Old 09-08-2014, 12:19 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
High CO means its running rich. I don't think the 95 is carburetor, so I don't know how to fix that, but at idle it means you are pumping too much fuel at the lower RPM.
In your case, I'd try to get a bottle of the above stuff, or just some HEET, pour it in the tank, bomb around then highway for about 30 minutes, get that bastard running nice and hot, then go directly to the smog place. Should help.
I got sick of smogging my crap so before I went to Classic Vehicle plates I would just take my pile to my favorite mechanic (who does a lot of work on classics) and say "make it pass". they'd bill me for the smog check and like an hour of labor.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #8 of 8 Old 09-08-2014, 07:22 PM Thread Starter
badtoy1986
Can you PM me a recommended mechanic?
