Guns - The Official Southern Nevada/Las Vegas Gun Thread - Page 51 - JeepForum.com
post #751 of 2624 Old 09-10-2013, 12:57 AM
Puck81
Handgun rounds don't travel at high enough velocities to cause significant cavitation. That's why rifle rounds are so much more effective. They're much faster and cause significant cavitation. Hollow points transfer more energy to the target rather than traveling through at relatively slow speed(compared to rifle rounds.)
Ok, that make a ton of sense. Thats why there is hollow point pistol rounds and not rifle rounds.(minus .223 PD hollow points)
Puck81 is offline
post #752 of 2624 Old 09-10-2013, 01:36 AM
Powrjunkey
Powrjunkey's Avatar
I've only ever seen 223 hollow point varmin rounds. Not to say there aren't 308 or others available though. Generally, you want a rifle round to be a FMJ. It's a lot more stable at distance and able to cause hydraulic cavitation because it retains its velocity better. Next time you're over, I'll open up a ballistics manual and show you the numbers. It's staggering the differences in velocity from pistol to rifle rounds. A couple of extremes here...a certain 45 load may produce a round that travels at less than 1000FPS(feet per second.) my 204 ruger, which is a 223 necked down to 204, travels at over 4000fps! Smaller bullet, but much higher velocity! Much greater hydraulic damage at the same distances. Sure, the 45 will have a larger entry and exit hole, but the 204 makes jelly inside!
Powrjunkey is offline
post #753 of 2624 Old 09-10-2013, 03:37 AM
andy02
Kind of... Velocity without the ability to transfer energy is useless. Most rifle hunting rounds are copper jacketed surrounding a lead core. You will also note that most rifle hunting rounds have either a blunted tip or a plastic tip. Both are designed to do the same thing. Allow the lead core to expand. The reason the lead core expands is to transfer energy otherwise all you have is an itty bitty hole all the way through the target. You get the same thing when trying to shoot a rabbit with a 9MM FMJ round. A little bitty hole all the way through the target. Even when using hollow points in the 9MM flavor on a rabbit, you may not get the expansion required to get a clean, humane kill. It really depends on a few different factors. Distance to target, relative velocity, size of the hollow pointed section and quite a few others can make a large change in how a round performs in the target. Next time you get a chance, check out a couple of youtube videos on 9MM rounds into ballistics gel. You will see that a FMJ round travels a good 6-8 inches into the gel before the wound channel opens up. The same thing happens inside the rabbit except that by the time it has traveled that far, it is already through the other side.
Edit: to help you out. Only about the first 3-4 minutes are relevant.
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
post #754 of 2624 Old 09-10-2013, 07:34 AM Thread Starter
Roobicon
Really? Hunting rounds are designed to expand and do as much damage as possible in order to kill humanely. Also, having been doing a lot of 600-1000 yd shooting, some of my most accurate rounds are HPBTs...hollow point boat tails. These are designed to break up on impact on a steel target.
2004 Roobicon
Clinging to my guns and my religion
Roobicon is offline
post #755 of 2624 Old 09-10-2013, 08:14 AM
ksturgio
Correct me if I'm wrong but rifle rounds tend to tumble once entering a target hence the small entry, large exit. I've nailed game with .223 and it looks like a .22 at entry and a massive exit. That's what I've always figured what was happening. I could also see it as just slug expansion but you would think that size of expansion would prevent exiting.
Well looks like we need to go call some coyotes and test our theories.
ksturgio is offline
post #756 of 2624 Old 09-10-2013, 09:08 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
I'm down.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #757 of 2624 Old 09-10-2013, 09:08 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Originally Posted by Roobicon
My weapon of choice for home defense is a 1911 loaded with hollow points. I have verified they do not pass through the walls of my dining room.
If somebody wants to survive an encounter with you they just need to wear a vest of kitchen tile.
-Andrew
Marn is offline
post #758 of 2624 Old 09-12-2013, 03:08 PM
ksturgio
Here is a pic of the new gun.
ksturgio is offline
post #759 of 2624 Old 09-12-2013, 03:18 PM
B0nez
WOW! that looks REALLY nice! Congrats!
B0nez is offline
post #760 of 2624 Old 09-12-2013, 04:19 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
want want want want want want want want want want want want want want WANT!
-Andrew
Marn is offline
post #761 of 2624 Old 09-12-2013, 04:31 PM
sirhk100
Fix your brakes
Khris
sirhk100 is offline
post #762 of 2624 Old 09-12-2013, 04:44 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Originally Posted by sirhk100 View Post
Fix your brakes
I'm going to try this weekend. i have the new prop valve. That isnt a money issue....
I dont know what to do if this doesnt fix/help.
-Andrew
Marn is offline
post #763 of 2624 Old 09-12-2013, 04:59 PM
sirhk100
Shut it! Just fix them!
Khris
sirhk100 is offline
post #764 of 2624 Old 09-12-2013, 05:03 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
come help?
-Andrew
Marn is offline
post #765 of 2624 Old 09-12-2013, 06:50 PM
sirhk100
I ain't a brake expert, you heard what I had to do with the race truck and that was only after I got a 25+ year auto tech over here to help me figure it out. LOL I'm much better at drilling holes in fuel lines!
Khris
sirhk100 is offline
