CRAWL's Project Recycle TJ for sale - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > Nevada Jeep Forum > CRAWL's Project Recycle TJ for sale
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Jeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06
Unread 02-14-2014, 10:15 AM   #1
John90XJ
Featured in CRAWL Magazine in May 2011, this '98 Jeep TJ has been built to the editor's specifications for a simple but no compromise rock crawler and trail rig. Known as Project Recycle, the Jeep is equally comfortable on the Rubicon as the rocks of Johnson Valley or Moab. It still has good street manners and can be driven on the road.
More photos here: http://reno.craigslist.org/cto/4329659220.html
Basics:
4.0 liter inline six with 62mm throttle body and cold air intake
32RH 3-speed automatic
NP231 t-case with TeraLow 4:1 box, TeraLow 2-Low and TeraLow super short SYE
Front axle is a Currie F9 high pinion with ARB Airlocker
Rear axle is Ford 8.8 with ARB Airlocker and c-clip eliminator
Chromoly shafts front and rear
Goodyear 37" MT/Rs on Trail-Gear Creeper Lock beadlock wheels, five total
TeraFlex LCG Pro suspension system with tuned Fox shocks and Tera bump cans
Full cage tig welded
Body is in good shape
Clean CarFax available for review
Hometown Reno, Nevada
Vehicle Type 1998 Jeep Wrangler TJ
Builder CRAWL Magazine, built January 2011
Chassis
Frame / Chassis Design Stock
Frame / Chassis Materials Steel
Cage / Cage Material Those Guys Rod & Customs, Bremerton, WA / 1.75" DOM, fully tig welded
Overall Wheelbase 95.5"
Overall Length 148"
Belly Pan Clearance 18" at 5psi tire pressure
Overall Height 79.5"
Wheel Track Width 80.5" front, 76.75" rear
Overall Weight 4300 estimated
Drivetrain
Front Suspension / Type / Materials TeraFlex LCG Pro 4-link, 1.75" x .250" wall DOM lower arms, 1.25" x .250" wall DOM upper arms with Tera Monster joints
Front Sway Bar Currie AntiRock
Front Shocks Fox 2.0 Pro 12" with remote reservoirs, tuned by AllTech Motorsports
Front Bump Stops TeraFlex Speed Bumps
Front Axle Housing Currie F9 housing with Currie high pinion 3rd, Reid Racing knuckles/Cs, Trent Fab trackbar bracket
Front Differential / Locker ARB AirLocker
Front Ring & Pinion / ratio Yukon 4.10:1
Front Axle Shafts Yukon Hardcore 4340 31 spline inners, Yukon D60 35 spline outers
Front U-Joints Yukon Super Joints
Front Drive Flanges / Hubs Yukon Hardcore D60 lockouts
Front Brakes Chevrolet one ton from Parts Mike
Front Steering Setup CRAWL custom high steering w/ Currie trackbar, Artec high steer arms, PSC hydro assist, gearbox & pump
Front Driveshaft Stock w/ Spicer components
Rear Suspension / Type / Materials TeraFlex LCG Pro triangulated 4-link with 1.75" x .250" wall DOM arms with Tera Monster joints
Rear Axle Truss Clayton Off Road
Rear Sway bar Currie AntiRock
Rear Shocks Fox 2.0 Pro 12" with remote reservoirs, tuned by AllTech Motorsports
Rear Bump Stops TeraFlex Speed Bumps
Rear Axle Housing Ford 8.8 with Superior Super 88 c-clip eliminator, TeraFlex bracket kit
Rear Differential / Locker ARB AirLocker
Rear Ring & Pinion / Ratio Factory 4.10:1
Rear Differential Cover Crane Hi Clearance nodular iron
Rear Axle Shafts Superior 4340 31 spline, dual drilled pattern
Rear Brakes Factory disc
Rear Driveshaft Tom Wood
Tire Make / Size Goodyear MT/Rs 37/12.50-17, new in 2012, set of five, at 97% or better
Wheel Make / Size / Bolt Pattern Trail-Gear Creeper Locks 17 x 9, 5 on 5.5", Jantz deflators
Powertrain
Engine Make Factory, approximately 186,000 miles on odometer, Brown Dog motor mounts, recent distributor
Engine Displacement 4.0 liters
Engine TQ 225
Engine HP 190
Engine Induction Normally aspirated w/ Superchips 62mm throttle body
Batteries Optima Yellow Top with Artec battery box
Radiator / Fans Factory
Air Intake Superchips TrailJammer cold air intake
Exhaust Stan's Headers, Auburn, WA / complete 2.25" custom exhaust
Muffler Flowmaster Hushpower muffler
Transmission Make Chrysler 32RH, Summit cast aluminum high capacity pan
Torque Converter Factory
Transfer Case(s) NP231 with TeraLow 4:1, TeraLow 2 Low and SYE, new 4:1 in 2013
Transfer Case(s) Shifter Advance Adapters 231 cable shifter
Fuel Containment Factory with Savvy Offroad aluminum skid
Body / Interior
Body / Body Panels Metal Cloak aluminum inner & steel outer fenders, factory full doors in matching white, ASD aluminum trail half doors
Body Modifications Savvy Offroad aluminum rockers, front & rear aluminum bumpers, aluminum corners, stainless rub rails, additional Trail-Gear rear bumper / tire carrier with Hi-Lift mount & Hi-Lift 48" jack
Skid plate / Material TeraFlex steel for oil pan/trans/t-case
Hood / Grille Factory
Soft Top Rampage Frameless soft top / SpiderWebShade.com sun cover
Armor Savvy Offroad gas tank skid / MetalCloak fenders
Steering Column / Wheel Factory tilt w/ cruise control
Seats / Harnesses PRP Comp High Backs / Crow Enterprizes 5-point
Lights Black Knight 12" 20-LED lightbar / Q-Star 7" HIDs / amber LED dust light / Savvy LED taillights
Winches Warn 9.5 Ti / MasterPull rope, Warn Hawse fairlead and MP thimble
Extras Blue Monkey SpeedoHealer, rear deck tool & gear box, Trail-Gear six quart carrier, Bestop windjammer, A-pillar mirrors & mounts
Sale will not include: iCom VHF radio, antenna & mount; Lowrance GPS & mount; co2 bottle or mount
Asking $19,900 / obo. Possible trade for cash and a 97+ Jeep Cherokee four door.
Located in Cold Springs outside Reno, Nevada. Flexible schedule for viewing. Any questions, don't hesitate to ask. There is a lot of detail above but it's possible I've forgotten a few things. This is not going to disappoint so if you're in the market for a truly turnkey crawler/trail rig, this is it.
Note: some photos are shown from the original magazine photo shoot and were done when the rig was on different tires/wheels. The rig currently has 37" Goodyears and Trail-Gear beadlock wheels.
John90XJ is offline   Reply With Quote Quick reply to this message
Unread 02-14-2014, 08:00 PM   #2
B0nez
Awesome looking rig - good luck with sale!
B0nez is offline   Reply With Quote Quick reply to this message
