San Jose, CA - Anyone want a side job installing my transfercase? - JeepForum.com
post #1 of 4 Old 02-07-2011, 12:03 PM Thread Starter
tkc
Hello everyone and thanks for looking. I've been pulling my hair out trying to get this fixed for years now, so I'm looking to fellow jeepforum members for help. If you're short on cash, have some free time, and looking for a side job, hopefully we can work something out.
Vehicle: 1996 ZJ Grand Cherokee Laredo, 4wd, V8, Automatic, Quadratrac.
Basically, I bought my Jeep ZJ a while back and it was missing the front drive shaft (or propeller shaft, as some call it). The only reason I figured someone took it out was because the transfer case went bad.
So I bought a transfer case to replace the one I have. It's the exact same model, direct swap.
My headache came in searching for a drive/propeller shaft. First, I bought one, only to find out it was too long.
Then, I bought another one that was a few inches shorter, only to find out that was still too long AND it had a busted cap on top, which I later found out was squirting gear lube out of.
So at this point, I'm frustrated and just want to pay for help to get my Jeep back to a 4wd.
I need someone to help me:
- Locate a working, good condition, correct length drive/propeller shaft.
- Remove old transfer case
- Prep and install replacement transfer case & driveshaft.
If you're interested, can you please send me an email or PM and we can go from there. Thank you so much!
Here's the old thread with pics of the parts: http://www.jeepforum.com/forum/f13/f...g-one-1143787/
tkc is offline
post #2 of 4 Old 02-07-2011, 07:04 PM
fredr1980
Not looking for a side job or anything but this is a fairly simple swap that you could probably do yourself in your driveway and save yourself some money... On ZJ's all you need is a 9/16 wrench to remove the 6 nuts holding the t-case to the transmission, a 5/16 wrench/socket to remove the bolts holding both drive shafts and a long flat-head screwdriver to pop the linkage from the transfercase... it's about an hour tops to do and the transfer-case isn't even that heavy. HTH .
Fred R.
05 LJ, 5.7L Hemi w/ 6-Speed. Narrowed, trussed & locked HP D44, trussed & locked F8.8 on 37" PBR's
fredr1980 is offline
post #3 of 4 Old 02-10-2011, 06:06 PM
Diamond-x
1991 XJ Cherokee
You can definitely do this yourself!
Call your Dad, or brother, or neighbor, or buddy. Buy some refreshment and pizza.
remove both drive shafts, save nuts/bolts in ziplock bags.
remove all linkage and electrical, vent connections to TC.
Support bell housing, Remove cross member
remove bolts to trans
put a floor jack under TC and pull it back to remove
replace with new TC
You CAN do this, and you'll be better off for it.
Diamond-x is offline
post #4 of 4 Old 02-18-2011, 04:30 AM
gregq
Check out Southbay Driveline. They may be able to change the drive shaft length for you.
Greg Quintana
gregq is offline
Low Rangers 4WDC - new club - San Jose,Ca rckjeep California Jeep Forum 33 04-29-2015 06:54 PM
San Jose 4X4 classes UberMX5 California Jeep Forum 1 02-23-2009 05:18 PM
Any good clubs in San Jose, CA tjrad California Jeep Forum 7 11-05-2007 10:35 AM
