roll call ORANGE COUNTY - Page 271 - JeepForum.com
post #4051 of 4591 Old 12-02-2013, 10:34 AM
MurdaJs
No problem, better safe than sorry!
Question guys: Anyone know a competent, reasonably-priced exhaust shop in the tustin/orange area? The closer the better, straight headers get a lot of attention
MurdaJs is offline
post #4052 of 4591 Old 12-02-2013, 07:54 PM
Ricochet88
I've used plaza muffler a bunch of times but the one in garden grove/ Westminster I know they have more than one location tho
Rick "woody"
93 zj wagoneer pkg, 5in iro lift, 33/10.5/15 bfgoodrich km2
my build thread
R.I.P. TROY EDWARDS "bigbluezj94"
Ricochet88 is offline
post #4053 of 4591 Old 12-03-2013, 12:11 AM
Delta347
Originally Posted by CJ7dreamer View Post
I have been up there quite a few times, it has a pucker factor to it, but like tjdualsport said be very careful of your line. Wildomar is probably a better place to go play, its all legal out there... All of the (edit: other), offshoots on Holly Jim are trespassing.
My in-laws live in Wildomar, I go out there quite often but have never hit those trails. I would love to some time. I've driven over the Ortegas and seems like there is opportunity up there and around the foothills on the Wildomar side.
I'd like to not roll or get arrested so I'll definitely err on the side of caution and plan a time when I can take a buddy!
I think either the morning of the 7th or 8th I will be going to Azusa Canyon if its open for some film shooting for a car show that wants offroad footage of my JP Jeep. If anyone else wants to tag along I'll probably post some information here later this week. Not sure which day we will go yet, remember $8 entry fee! But you may get to see 2-3 JP Jeeps haha.
ON A SIDE NOTE: Does anyone have experience swapping rings/pinions in an axle? I have been looking for a 8.8 with 4:10 from the Junkyard for years and there is never one when I go. I have a set of 4:10 gears in a box somewhere for an 8.8 and I know the carrier is the same between the 3:55 (or whatever the common ratio is) and the 4:10. So I am considering just getting a disc brake leaf 8.8 and swapping the gears myself. I have access to a mill, micrometers, depth gauges, presses, and a decent amount of tools at the Lab I work at.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #4054 of 4591 Old 12-09-2013, 01:21 PM
MurdaJs
Anyone have a 231j or 242j with external slip yoke they would like to sell?
I have a 231d hd, which would require a slip yoke eliminator (any 231j sye will work) to fit a jeep. Has a wider chain than 231j, if anyones planning to sye a 231j, this 231d hd would be a bit of an upgrade, and a jeep tcase would allow my stock driveshaft to work.
Thanks
MurdaJs is offline
post #4055 of 4591 Old 12-10-2013, 07:57 PM
MurdaJs
Dude delta i dont know how you are havin so much trouble finding an 8.8. I was tripping over eligible explorers at tye anaheim and stanton yards. Even ecology in santa fe springs.
Btw, 4.0 zj guys, there was a nice looking magnaflow muffler and tailpipe for a 4.0 at the ecology today. Nicr and shiny and no forklift **** ups
MurdaJs is offline
post #4056 of 4591 Old 12-11-2013, 01:22 AM
neto_09
Hi everyone, I just joined this thread, hope to find some friends and go wheeling one of these days, and have some advises from some experienced jeepers.
neto_09 is offline
post #4057 of 4591 Old 12-11-2013, 08:59 AM
Delta347
Originally Posted by MurdaJs
Dude delta i dont know how you are havin so much trouble finding an 8.8. I was tripping over eligible explorers at tye anaheim and stanton yards. Even ecology in santa fe springs. Btw, 4.0 zj guys, there was a nice looking magnaflow muffler and tailpipe for a 4.0 at the ecology today. Nicr and shiny and no forklift **** ups
Oh there is no shortage of 8.8.... the problem is every time I go there is never a 4:10 8.8 only the higher 3.55 or 3.07 or whatever ratio which is common. I have a 4:10 ring and pinion but I have mixed feelings about regearing an 8.8 if I can help it.
/End Transmission
Delta347 is offline
post #4058 of 4591 Old 12-11-2013, 11:41 AM
MurdaJs
How are you determining ratio when youre at the yard?
MurdaJs is offline
post #4059 of 4591 Old 12-11-2013, 04:53 PM
Delta347
By the tag on the differential and on the door, I always check both. If one or the other is missing I still generally believe it if the system looks untouched.
The door label has the axle codes and the metal tag on the housing does too.
/End Transmission
Delta347 is offline
post #4060 of 4591 Old 12-13-2013, 06:37 PM
MurdaJs
PYP stanton has an xj that had about 3 inch rustys lift. Only thing left are all 4 shocks, look real new, like 3 months old at the most.
3 hp d30s, non disco, 3.73 gears also. And a bunch of 8.8s but i dunno the ratio
MurdaJs is offline
post #4061 of 4591 Old 12-14-2013, 12:41 AM
EYPUFF
EYPUFF's Avatar
if i grab one of those hp d30s.. will i need a longer driveshaft? and anyone know how much it might cost to have a shop replace it w/ my dying one? getting pretty tired of working on the jeep..
1995 GC 5.2 Limited V8
Green Jeep Club Member # 32
EYPUFF is offline
post #4062 of 4591 Old 12-14-2013, 01:59 AM
MurdaJs
I dunno about shaft length, are you asking what it would cost for a full axle swap? Itll bolt right in so maybe 2-3 hours shop rate, but if you can pull it you can install it. Driveshaft shortening and balance should be about $100, not including u joints if you need those too. If the slip joint is shot theres no saving it
MurdaJs is offline
post #4063 of 4591 Old 12-14-2013, 02:08 AM
MurdaJs
Id imagine there should be enough slip built into the ds to make up for the difference. But if not i have 3 different length driveshafts, lemme find out which one i need and the other two will be available. Ill know on sunday
MurdaJs is offline
post #4064 of 4591 Old 12-14-2013, 02:16 AM
cgcarpenter
How much for the hp30?
cgcarpenter is offline
post #4065 of 4591 Old 12-14-2013, 02:44 AM
MurdaJs
They want like 270, but she wasnt sure if that included brakes and steering etc.
In case i was unclear theyre at the pull your part, in stanton.
MurdaJs is offline
Orange County, CA ocTJ California Jeep Forum 7 12-24-2009 06:35 PM
looking for jeepers out in southern orange county, CA Fatsooo California Jeep Forum 2 11-18-2009 07:25 PM
Orange County Mountain Climb: Sat Aug 8, 2009 SantaAnaSlim California Jeep Forum 0 08-07-2009 08:05 PM
New YJ owner reaching out to orange county yj owners yellowdogsyj California Jeep Forum 4 01-19-2009 10:13 AM
Anyone in Orange County, CA? thebeast64 California Jeep Forum 3 12-09-2008 03:55 PM
