Roll Call: LOS ANGELES COUNTY! - Page 926 - JeepForum.com
 2Likes
post #13876 of 30337 Old 10-01-2013, 08:29 AM
THOR114
Copy...lol
THOR114 is offline
post #13877 of 30337 Old 10-01-2013, 10:51 AM
zombiehunta666
Hey do any of you run synthetics in your oil?
@Zombiehunta666
*lllllll*
The birth of the ZombieHunta!
http://www.jeepforum.com/forum/f22/birth-zombiehunta-1612329/
zombiehunta666 is offline
post #13878 of 30337 Old 10-01-2013, 10:53 AM
zombiehunta666
Any of you run synthetics in your oil?
@Zombiehunta666
*lllllll*
post #13879 of 30337 Old 10-01-2013, 10:55 AM
Michaelgoesrawr
I run it in my axles. Engine gets plain old dino oil.
Michaelgoesrawr is offline
post #13880 of 30337 Old 10-01-2013, 11:04 AM
zombiehunta666
Ok. That makes me want to clarify, I guess there are several place were oil will go. :haha:
Yes I was just referring to engine oil. I run it in my BMW because that's what was in it when I got it. It's been nice to not have to change the oil every two months.
With the low speed off roading, idling, and in town commute to work I was thinking that maybe worse for the rig.
@Zombiehunta666
*lllllll*
post #13881 of 30337 Old 10-01-2013, 11:13 AM
Michaelgoesrawr
I don't think its bad for the jeep. Just not worth the cost for people. Synth runs cooler so itd probably be better id imagine. Ive heard switching to synth could cause leaks to get worse because the particles are smaller. Again, not sure though
post #13882 of 30337 Old 10-01-2013, 11:21 AM
danielbuck
1946 CJ2
Dino oil all around in both of mine.
danielbuck is offline
post #13883 of 30337 Old 10-01-2013, 11:30 AM
MPond
I run full synthetics all around for a variety if reasons.
In the motor because the synthetic holds up better to the heat of the turbo.
In the axles because I flat-tow for thousands of miles at highway speeds, and it helps dissipate heat from the higher gears.
In the transfer case for the same flat-towing reason as above.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #13884 of 30337 Old 10-01-2013, 11:34 AM
zombiehunta666
Someone else said Dino oil. What's that?
@Zombiehunta666
*lllllll*
post #13885 of 30337 Old 10-01-2013, 11:43 AM
MPond
Non-synthetic oil is mostly decomposed dinosaurs (and other hydrocarbons).
From Urban Dictionary:
1. dino oil
Motor oil derived from traditional hydrocarbon/crude-oil sources (decomposed dinosaurs and plant matter). Also often referred to as "mineral" based oil. This in in contrast to the new synthetic lubricants which have to be "manufactured" from various chemicals rather then just simply boiled off from a crude-oil source. Synthetics are seens as superior to dino oil since the manufacturing process is more controlled and may not require the polymer additives to achieve the same desirable lubricating properties. Synthetics are also more expensive then dino oil.
MPond is offline
post #13886 of 30337 Old 10-01-2013, 11:47 AM
danielbuck
1946 CJ2
dead dinosaurs
post #13887 of 30337 Old 10-01-2013, 11:51 AM
THOR114
dead dinosaurs
I feel like one as well. I think i screwed up my test (((((
THOR114 is offline
post #13888 of 30337 Old 10-01-2013, 12:01 PM
clg82
Have run mobile1 since I bought it...no problems here..
clg82 is offline
post #13889 of 30337 Old 10-01-2013, 01:48 PM
SkylarM
Hey, Matt. What do you put in your transfer case?
SkylarM is offline
post #13890 of 30337 Old 10-01-2013, 01:51 PM
MPond
Not sure. I'll have to look in the garage when I get home.
I think it was Lucas Oil, but I'm not sure.
MPond is offline
roll call ORANGE COUNTY shortbussrydah California Jeep Forum 4590 12-29-2015 08:44 PM
Roll Call Ventura County blue52 California Jeep Forum 41 05-05-2013 01:02 PM
Roll cage fabricator in Orange County, Ca.? Stinkbug California Jeep Forum 6 11-29-2010 11:11 PM
Roll Call: Who's Going to Big Bear Over the 4th? roadking California Jeep Forum 12 07-07-2010 09:04 AM
Nor Cal Roll Call rugbygode2 California Jeep Forum 54 11-25-2008 11:54 PM
