Roll Call: LOS ANGELES COUNTY! - Page 736 - JeepForum.com
 4Likes
post #11026 of 30351 Old 05-12-2013, 04:42 PM
aw12345
Originally Posted by MPond View Post
It was an existing problem. They did a leak down test before the installation and found a 60% loss on cylinder #4. I'm hoping its just a head gasket, and not something worse. If only got 30k on the clock, so can't imagine it being something else.
I told them to go ahead with the turbo install, and I'd get it taken care of as soon as I got the Jeep back. Got it back Friday night, and don't have time to do it myself, so I'm taking it in tomorrow to a local mechanic.
If it puked coolant while they did that it's a head gasket, now has the check engine light been on? That much leakage should cause a misfire that the obd 2 system will detect. that or the messed up on their test. 60% leakage puts you in the area of major engine problems
aw12345 is offline
post #11027 of 30351 Old 05-12-2013, 05:50 PM
MPond
No coolant leakage, no check engine light, runs good, etc... They thought the same thing, but they did the test 4 times. Same results each time on cylinder #4.
The mechanic will recheck it to be sure.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #11028 of 30351 Old 05-12-2013, 05:54 PM
aw12345
What did they come up with for compression when they checked that?
Also a running compression check at idle and higher rpm can be quite revealing
aw12345 is offline
post #11029 of 30351 Old 05-12-2013, 06:00 PM
Hotshot
Doesn't sound right to me either. If compression was down that much in one cylinder i wouldn't think it would run all that smooth.
Hotshot is offline
post #11030 of 30351 Old 05-12-2013, 06:15 PM
MPond
Yeah - I was thinking the same thing.
Hopefully I'll get some answers to all of these questions in the next couple days.
MPond is offline
post #11031 of 30351 Old 05-12-2013, 09:26 PM
Hotshot
Just BBQ'd some ribeye steaks, man were they good. Marinated them in stubs steakhouse marinade, diluted with a can of Budweiser, a quarter bottle of Chris n pits hot BBQ sauce and about a cup of water. I let them marinate for 5 hours. Normally we don't marinate Ribeye Steaks but I'm glad we did this time. Sautéed some asparagus, baked some potatoes. The best BBQ'd steaks I've ever had. People in our family here who rarely ever finish their steak eat every last bite.
Instead of throwing the marinade out I took two tri tips and put them in the same container and back into the fridge to marinate for a coupe of days. Mid week well BBQ one and freeze the other.
You guys need to try this combination of marinade on your next steaks.
Hotshot is offline
post #11032 of 30351 Old 05-12-2013, 11:43 PM
danielbuck
1946 CJ2
Nice, will have to try that sometime Gary!
Matt, TURBO! nice :-D without laying into it much, do you notice any difference? Is it sized so it builds boost at a lower RPM?
I just got the turbo for my little 2.2L diesel. It's cute looking, haha! I'll take a photo of it. Apparently it's sized correctly for a 2.2L diesel, we'll see!
Here it is, it's an IHI RHF4
danielbuck is offline
post #11033 of 30351 Old 05-13-2013, 12:52 AM
MPond
Yeah - if I get into the boost at low RPM it pulls beautifully! With only 1/4 throttle at 1800 RPM is pulls hard like a small block V8. If I get into high RPM it's ugly right now, but I'm guessing that's related to my compression issue.
MPond is offline
post #11034 of 30351 Old 05-13-2013, 10:06 AM
aw12345
Does it bog at higher rpm or start misfiring?If it just holds back, but goes again when you let up the gas it's just starving for fuel
aw12345 is offline
post #11035 of 30351 Old 05-13-2013, 11:51 AM
NBMgreg
How did they tune the thing? Did they put it on a dyno or anything? Were any fuel upgrades needed?
NBMgreg is offline
post #11036 of 30351 Old 05-13-2013, 03:35 PM
MPond
Not a misfire (no check engine lights), but it knocks pretty bad and retards the timing enough that the power cuts momentarily.
MPond is offline
post #11037 of 30351 Old 05-13-2013, 03:37 PM
MPond
They upgraded to larger injectors. They gave me the tune they used on the other 2 LJs they used to prototype the kit, but they couldn't dyno it yet because of the compression issue. They want the Jeep back when the compression problem is fixed so they can tinker with it.
MPond is offline
post #11038 of 30351 Old 05-13-2013, 04:26 PM
aw12345
Engine knock or high speed pinging? If the knock is there at idle and up good change a piston skirt broke
aw12345 is offline
post #11039 of 30351 Old 05-13-2013, 06:11 PM
SkylarM
Hey Matt, think we could get a picture in that engine bay?
SkylarM is offline
post #11040 of 30351 Old 05-13-2013, 08:02 PM
MPond
Knock, much louder than pinging. But nothing at idle. Only under boost at higher rpm.
MPond is offline
roll call ORANGE COUNTY shortbussrydah California Jeep Forum 4590 12-29-2015 08:44 PM
Roll Call Ventura County blue52 California Jeep Forum 41 05-05-2013 01:02 PM
Roll cage fabricator in Orange County, Ca.? Stinkbug California Jeep Forum 6 11-29-2010 11:11 PM
Roll Call: Who's Going to Big Bear Over the 4th? roadking California Jeep Forum 12 07-07-2010 09:04 AM
Nor Cal Roll Call rugbygode2 California Jeep Forum 54 11-25-2008 11:54 PM
