Roll Call: LOS ANGELES COUNTY! - Page 690 - JeepForum.com
 5Likes
post #10336 of 30362 Old 04-07-2013, 10:53 AM
danielbuck
1946 CJ2
Yea, I'm not so good at picking lines, haha! I've still got alot to learn, each time out though, I get more and more comfortable with my jeep. But for the most part, I try to follow the guy in front of me, unless he had trouble, haha!
danielbuck is offline
post #10337 of 30362 Old 04-07-2013, 11:00 AM
aw12345
Then a good spot is right behind Mike.
Changing your gearing will help finesse though, you still run 4.10's right?
You will be so much happier with 4.88's
aw12345 is offline
post #10338 of 30362 Old 04-07-2013, 11:05 AM
clg82
Originally Posted by aw12345 View Post
Daniel it becomes even more fun when you get to the part where you ignore the spotter and pick the line you like best.
Poppa's son, this run was posted all you had to do was show up for a good time
I'm not over at MJR very often tho so you guys need to come over here and give us guys a heads up!
clg82 is offline
post #10339 of 30362 Old 04-07-2013, 11:12 AM
aw12345
Excuses, excuses, excuses,excuses,excuses
If at all possible you do not want to miss runs with Mike Koher, trust me on that one.
aw12345 is offline
post #10340 of 30362 Old 04-07-2013, 12:03 PM
danielbuck
1946 CJ2
Yea, I've been thinking about 4.88's, just don't want to put more money into the TJ just yet, haha! I hear typical labor for a gear swap in both differentials is around $1000 + or -. I don't know if swapping gears is something I'd want to tackle on my own.
Stalling out less while at odd angles would be nice though
post #10341 of 30362 Old 04-07-2013, 12:12 PM
aw12345
Robert from RKhaus does them for around 200-300 bucks and axle labor there are some mobile guys that come to your house that do it in that range.
It will be the best thing you ever do for your Jeep
gears 200 install kit 100 labor around 300 an axle that is about what you should shop for when looking for somebody to get the job done.
It's more about control when crawling than stalling, no surging or lucrching forward, just smooth crawling without use of the clutch
aw12345 is offline
post #10342 of 30362 Old 04-07-2013, 12:18 PM
danielbuck
1946 CJ2
about 300 labor per axle, so around $600 labor total is what I should be looking at? I'd probably pick up the parts and install kit myself. Randy's Ring & Pinion still a good place to order through?
Yea one thing I have trouble with, is when I'm crawling up or down something, and I need to stop. I press the brake and try to slowly press the clutch, but I always get a big lurching (which is fun when it's tippy.... haha!). I've tried starting to press the clutch first and then the brake (well, more or less together, but airing on the side of hitting the clutch a bit sooner than the brake) But I can't seem to ever do it smoothly.
I can pretty much always get moving again smoothly, even if I'm at an odd angle. I'm alot better at slowly letting out the clutch and brake at the same time than I am pushing them in I guess. Usually no lurching when I need to creep forward again. But when I have to stop again, it lurches, haha!
post #10343 of 30362 Old 04-07-2013, 12:27 PM
aw12345
I would get a quote from Robert at RKhaus, he carries Yukon gears and parts and has very good prices, and he does installs at a very reasonable labor rate. He probably wants you to just bring the axles though.
Some of the lurching is the driveline unwinding. In a spot like that try taking it out of gear, let the clutch out for a sec or two and then see how it takes off. I can stop on a steep hill and still take off on it without the front end coming upI let it idle let the clutch barely grab then let go of the brakes and give it just a little bit of gas so it doesn't stall. Good vrawl ratio helps tremendously with that. You got an excellent transfercase ratio, the 6 speed has a nice low first gear, all that is missing is a good axle gear ratio.
Then onto the front unloading, this fun stuff never ends
aw12345 is offline
post #10344 of 30362 Old 04-07-2013, 02:47 PM
Hotshot
Art I'm getting ready to do gears and axles also, same set up as Daniel. How do you think the 4.88's will be on the freeway?
I talked to Robert about a year ago, at that time he said you could bring the complete jeep over.
Hotshot is offline
post #10345 of 30362 Old 04-07-2013, 02:52 PM
MPond
Are you Auto or 6-spd? What size tires are planning to stay with?
I did a lot of research when I did my gears, and with the 6-spd and 33's, 4.56 seemed to be the recommendation I got most often and from a lot of different people. I never intended to go above 33's, so that's what I did, and I'm really happy with them.
And there's enough gear left there that I could move to 35's, and I've been considering doing that, but I've got a lot of tread left on my 33's.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #10346 of 30362 Old 04-07-2013, 03:07 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Found the dogs owner. Asian guy who only knew how to say thank you. Meh.
Michaelgoesrawr is offline
post #10347 of 30362 Old 04-07-2013, 03:15 PM
clg82
if you did more reading and research in the forums than asking in this thread your post count would be half as much as it is now...........help people out in the forums instead of posting about the best place to get a breakfast burrito.....
clg82 is offline
post #10348 of 30362 Old 04-07-2013, 03:20 PM
Hotshot
I've been beggin you to take us back to cougar buttes for a long time now father.....it's always excuse after excuse just like when i was a kid.....
DUDE, last time I took you there you spazzed and went all, "ooh lookie at me I'm a hardcore rock crawler" and you broke your jeep 10 minutes into the trail. Your momma told me you had nightmares and wet the bed for two weeks after that trip. Your momma sent me a email telling me to make excuses when you mention that trail. Just WHAT AM I SUPPOSED TO DO?
Hotshot is offline
post #10349 of 30362 Old 04-07-2013, 03:22 PM
Hotshot
That's it, where's my belt?
Hotshot is offline
post #10350 of 30362 Old 04-07-2013, 03:24 PM
Hotshot
6 speed, going to 35's soon. Good info, thanks.
Hotshot is offline
roll call ORANGE COUNTY shortbussrydah California Jeep Forum 4590 12-29-2015 08:44 PM
Roll Call Ventura County blue52 California Jeep Forum 41 05-05-2013 01:02 PM
Roll cage fabricator in Orange County, Ca.? Stinkbug California Jeep Forum 6 11-29-2010 11:11 PM
Roll Call: Who's Going to Big Bear Over the 4th? roadking California Jeep Forum 12 07-07-2010 09:04 AM
Nor Cal Roll Call rugbygode2 California Jeep Forum 54 11-25-2008 11:54 PM
