Roll Call: LOS ANGELES COUNTY! - Page 504 - JeepForum.com
 2Likes
post #7546 of 30310 Old 12-16-2012, 10:27 AM
clg82
Ok fellas, heres an update to my clunk......it is in fact my REAR DRIVESHAFT....removed it this morning, and the clunk disappeared.....inspected all the ujoints and they are all perfectly fine.......now where do i go from here.....it seems like when i depress the clutch pedal it is removing torque from the drivetrain and when adding it again it is causing the rear driveshaft to "re-engage" so to speak and thus for causing my clunk.....any suggestions?!?
clg82 is offline
post #7547 of 30310 Old 12-16-2012, 10:37 AM
Hotshot
With the rear drive shaft disconnected from the rear end. When you try to turn the rear end yoke by hand, how much does it turn before catching? If its approx an 1/8 or less like Art is saying, the diff may not be the problem.
Hotshot is offline
post #7548 of 30310 Old 12-16-2012, 10:39 AM
clg82
It only moves about 1/8
clg82 is offline
post #7549 of 30310 Old 12-16-2012, 10:56 AM
aw12345
Drive it with the rear drive shaft out and in 4 wheel drive. That should pretty much eliminate everything from the transfercase back. Then repeat with the rear driveshaft in and the front one out and still in 4 wheel drive
aw12345 is offline
post #7550 of 30310 Old 12-16-2012, 10:56 AM
Hotshot
That's good. When you hear this clunk, do you also feel it?
Hotshot is offline
post #7551 of 30310 Old 12-16-2012, 10:58 AM
clg82
I drove it with the jeep in 4wd and the rear driveshaft out. And the clunk is no longer there.
clg82 is offline
post #7552 of 30310 Old 12-16-2012, 11:03 AM
clg82
I feel it In the shifter as well as the clutch pedal itself.
clg82 is offline
post #7553 of 30310 Old 12-16-2012, 11:08 AM
aw12345
Check the U joints and the centering ball of the cv joint of the rear driveshaft.
aw12345 is offline
post #7554 of 30310 Old 12-16-2012, 11:09 AM
clg82
All ujoints in the rear driveshaft are new. And looking at them in perfect working order.
clg82 is offline
post #7555 of 30310 Old 12-16-2012, 11:13 AM
aw12345
What about the CV joint? They normally do not clunk, also when in gear if you let of the gas kinda abruptly and stomp on it again does it clunk or jerk?
aw12345 is offline
post #7556 of 30310 Old 12-16-2012, 11:25 AM
Hotshot
Any jerking, or learching forward when this happens? Just wondering if there's a delayed reaction in your clutch slave cylinder?
Hotshot is offline
post #7557 of 30310 Old 12-16-2012, 11:26 AM
Hotshot
Rear bumper/swing away, last time I shook his, it was way loose.
Hotshot is offline
post #7558 of 30310 Old 12-16-2012, 11:40 AM
clg82
cv joint looks fine......the clunk only happens when the clutch is engaged, it doesn't feel like a control arm bushing is bad (all savvy JJ arms in the rear)
clg82 is offline
post #7559 of 30310 Old 12-16-2012, 11:41 AM
clg82
no jerking or learching, clutch work as it's supposed too...
clg82 is offline
post #7560 of 30310 Old 12-16-2012, 11:42 AM
clg82
LOL i doubt the rear bumper/swing away would make a clunk thru my shifter.....let's try to get back on track ok pops
clg82 is offline
roll call ORANGE COUNTY shortbussrydah California Jeep Forum 4590 12-29-2015 09:44 PM
Roll Call Ventura County blue52 California Jeep Forum 41 05-05-2013 02:02 PM
Roll cage fabricator in Orange County, Ca.? Stinkbug California Jeep Forum 6 11-30-2010 12:11 AM
Roll Call: Who's Going to Big Bear Over the 4th? roadking California Jeep Forum 12 07-07-2010 10:04 AM
Nor Cal Roll Call rugbygode2 California Jeep Forum 54 11-26-2008 12:54 AM
