Roll Call: LOS ANGELES COUNTY! - Page 1657 - JeepForum.com
 2Likes
post #24841 of 30337 Old 08-05-2014, 04:37 PM
clg82
Originally Posted by RWKHausSupply View Post
Highly doubtful. There is more poss that the labor (R&R) of the sensor(s) for the truss and gussets, and maybe gear work, etc, caused it to fail somehow. Or someone forgot to put the speed sensor/ABS bolt back in the sensor when they last worked on it? If they did forget, it would have been fine for a while till it was shocked around long enough and hard enough for it to walk up out of the port some, and away from the reluctor ring.
they expensive to replace...?
clg82 is offline
post #24842 of 30337 Old 08-05-2014, 04:42 PM
RWKHaus
1990 XJ Cherokee
The labor to have someone do it at the dealer is likely more than the sensor.
I have never had to pay or inquire so I dont know though.
All you have to do is pull tire, remove caliper bracket bolts (do not remove just the caliper, remove whole assembly with the (2) 21MM head bolts), slide rotor off then you can see the sensor recessed in to the Unit bearing flange. I would do this and see if there is a bolt in there and if its tight.
RWKHaus is offline
post #24843 of 30337 Old 08-05-2014, 04:55 PM
SkylarM
Gears is the BIGGEST RIP OFF out there I feel. And reason why I got into them. A Slow team of two can get a JK Rubi (worst of the XJ, TJ, YJ, JK rigs) regeared in 3 hours (or less) if they are proficient and the right tools. Wholesale parts direct to the shop, are about 250$ for a regear. SO when 4wheel parts, Genwronx, JXX, etc charge you 1200-1800$ for a regear its like they are profiting about 150-200$ PER HR. Its crazy.
Well I think you hit the nail on the head. And I'd guess that the price ends up being somewhat understandable given the high overhead costs some of these shops have and the level of skill a technician needs in order to re-gear proficiently every time.
SkylarM is offline
post #24844 of 30337 Old 08-05-2014, 05:17 PM
zombiehunta666
I checked the sensor. Its connected. There's a bracket that seems to be tweaked that would hold it in place above the axle u joint. Could the sensor have hit that and caused it to fail? I heard the sensor can be found in auto parts stores?
@Zombiehunta666
*lllllll*
The birth of the ZombieHunta!
http://www.jeepforum.com/forum/f22/birth-zombiehunta-1612329/
zombiehunta666 is offline
post #24845 of 30337 Old 08-05-2014, 06:09 PM
clg82
too much work for you zombie take it to the dealer...
clg82 is offline
post #24846 of 30337 Old 08-05-2014, 06:23 PM
zombiehunta666
I was gonna ask to borrow you floor jack. Probably right.
@Zombiehunta666
*lllllll*
post #24847 of 30337 Old 08-05-2014, 06:42 PM
zombiehunta666
Whelp. That sucks. Looks like I got bad head. Abs will have to wait until I get better head. :atomic: I thought the head problems were 2011.
@Zombiehunta666
*lllllll*
post #24848 of 30337 Old 08-05-2014, 08:00 PM
clg82
Bad jeep news all around this place lately. Sucks about your misfortune zombie.
clg82 is offline
post #24849 of 30337 Old 08-05-2014, 08:05 PM
aw12345
Originally Posted by Hotshot View Post
Interesting. I wonder why they didn't tell me it could be straightened. I'll get back to you on this tomorrow, I may take you up on that offer.
Brute4ce posted this in the other thread
Bob myers, myers engineering in Santee....very well know in the off road industry news. Been straightening axles since the wells Fargo coach....
Hell
Probably straightened axles in the eqyptians stone carts back in pyramid days....
All in good fun he's older and don't bring him a dirty axle he will send you to clean it before he touches ot...
He is a artist with custom axle housings, tubes and building em from scratch as well as a master and getting them straight as a arrow.
aw12345 is offline
post #24850 of 30337 Old 08-05-2014, 08:06 PM
zombiehunta666
Agreed.
@Zombiehunta666
*lllllll*
post #24851 of 30337 Old 08-05-2014, 09:06 PM
stickerz
Nah I don't think there's anything Shifty about it. I wouldn't think simple repairs like an axle u joint, replacing a locker, or a re gear would call for the installer to check for a bent axle tube. It's not like it's noticeably bent, it's just a slight bend in it.
Keep in mind I took it in for a left front broken axle u joint. It was under warranty along with the axle. They replaced the complete axle shaft and u joint at no charge. That's when we found out the locker was also damaged. I wasn't planning on RE gearing until closer to Christmas but beings I had to put a new locker in right now I figured I'd save a little labor having the front gears done right now. Well after it was all installed they tore the front back down because of a clicking noise. They suspected a defective bearing so they took the new ones out and inspected them and didn't see any issue with them but went ahead and reinstalled it again with another new set of bearings just incase. It was still clicking. That's when they figured out that the right side axle tube is bent. They think the clicking is because the axle is in a binding a little.
Stan told me he could get me a currie housing for $2,100 and stick all these parts in it but I guess Currie's Dana 44 housing only excepts JK parts. So then he says we could go with a teraflex housing and stick all my parts in it. I'd be out the door for $6,200.00 going that route. I don't know anything about the teraflex housings.
I'm just trying to figure out if there's any other options? Been surfing the web and not coming up with anything but a headache.
You could also grab a bare 44 housing and have jpi put some brackets on
stickerz is offline
post #24852 of 30337 Old 08-05-2014, 09:14 PM
aw12345
That's a lot of coin for a D44 housing. See above for your solution will cost ya hell of a lot less, you owe me a Beer Poppa
aw12345 is offline
post #24853 of 30337 Old 08-05-2014, 09:36 PM
Hotshot
More like a six pack. Lol Thanks.
Hotshot is offline
post #24854 of 30337 Old 08-05-2014, 09:47 PM
aw12345
Your welcome bud, when your darling is all fixed I ought to teach you a few wheelin moves So you don't bend er up again or atleast have fun trying to do so
aw12345 is offline
post #24855 of 30337 Old 08-05-2014, 10:25 PM
zombiehunta666
@Zombiehunta666
*lllllll*
roll call ORANGE COUNTY shortbussrydah California Jeep Forum 4590 12-29-2015 08:44 PM
Roll Call Ventura County blue52 California Jeep Forum 41 05-05-2013 01:02 PM
Roll cage fabricator in Orange County, Ca.? Stinkbug California Jeep Forum 6 11-29-2010 11:11 PM
Roll Call: Who's Going to Big Bear Over the 4th? roadking California Jeep Forum 12 07-07-2010 09:04 AM
Nor Cal Roll Call rugbygode2 California Jeep Forum 54 11-25-2008 11:54 PM
