Roll Call: LOS ANGELES COUNTY! - Page 1126 - JeepForum.com
 5Likes
post #16876 of 30353 Old 12-17-2013, 07:29 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Originally Posted by NBMgreg
if i win, i'm buying everybody new tom woods driveshafts. got the dreaded angry sparrows this morning, pulled the front driveshaft and quickly found out it was the rear shaft. got to work, ripped out the rear shaft and found the output shaft yoke nut completely loose, backed way off, able to turn by hand! been slowly slowly getting the driveshaft taken apart between work breaks, and found that all u joints, AND the centering ball (angry sparrows culprit) are greasable. that seems dumb to me, no way to grease that crap without popping out u joints. I've never greased them since install 2 years ago. hoping a good cleaning/greasing will fix the squeak rather than $100 worth of ujoints and centering ball garbage. Then i have to see why that yoke nut because lose, and figure out where the hell to get a new one (pretty sure they're not reusable, but not sure), and figure out how hell to get it torqued to 180ft lbs without an impact gun. yayyyy!
Get yourself a nice 200 ft lb torque wrench, a pipe that'll slide over it and a friend to help. Easy peasy.
Michaelgoesrawr is offline
post #16877 of 30353 Old 12-17-2013, 07:30 PM
NBMgreg
that's probably what i'll do. Couldn't believe it when i saw that damn thing completely lose. a little scary to say the least.
NBMgreg is offline
post #16878 of 30353 Old 12-17-2013, 07:34 PM
NBMgreg
Skylar what did you do to keep the yoke/output shaft from spinning? Keep it in gear? Blocks of wood Wedged against the yoke?
NBMgreg is offline
post #16879 of 30353 Old 12-17-2013, 07:39 PM
aw12345
Originally Posted by NBMgreg View Post
did you reuse the same nut? if not where did you get a new one? trying to find one locally tomorrow
Red loctite is your friend, will keep it from working loose. J E reel in Pomona can supply yokes, spicer U joints and centering ball. You grease the centering ball with a grease needle. Loosen the shaft from the rear yoke and you can get at the grease fitting for the centering ball
aw12345 is offline
post #16880 of 30353 Old 12-17-2013, 07:54 PM
Mr_Speakeasy
He cant buy friends though.
Mr_Speakeasy is offline
post #16881 of 30353 Old 12-17-2013, 08:13 PM
aw12345
200 ft lbs is nothing, try crushing the crush sleeve on the pinion of a 14 bolt axle, my big 1100 ft/lbs max torque impact wrench looked at it and quivered. Had to do it the hard way was sore for weeks after
aw12345 is offline
post #16882 of 30353 Old 12-17-2013, 08:35 PM
NBMgreg
driveshaft is all back together. feels much better and makes no noise so far.. i'll work on getting that yoke nut torqued down tomorrow, then we'll see how it rides.
Art, how would you go about torquing the nut without an impact? If i put it in gear and let the engine/tranny hold the yoke still, will that damage anything internally when i'm cranking on it?
NBMgreg is offline
post #16883 of 30353 Old 12-17-2013, 09:05 PM
clg82
driveshaft is all back together. feels much better and makes no noise so far.. i'll work on getting that yoke nut torqued down tomorrow, then we'll see how it rides. Art, how would you go about torquing the nut without an impact? If i put it in gear and let the engine/tranny hold the yoke still, will that damage anything internally when i'm cranking on it?
When I did my SYE I had to put the jeep in 4 low to keep the yoke from spinning.
clg82 is offline
post #16884 of 30353 Old 12-17-2013, 09:25 PM
SkylarM
I went off a writeup online. I think Stu Olsens site... Maybe 4x4xplor. One if the two, but it Said put in gear, which worked for me.
And zombie... I saw your street queen twin today.... I'll post a pic in a sec
SkylarM is offline
post #16885 of 30353 Old 12-17-2013, 09:26 PM
aw12345
Lowrange, first gear and chock the wheels ought to do it.
aw12345 is offline
post #16886 of 30353 Old 12-17-2013, 09:33 PM
zombiehunta666
Originally Posted by SkylarM
I went off a writeup online. I think Stu Olsens site... Maybe 4x4xplor. One if the two, but it Said put in gear, which worked for me. And zombie... I saw your street queen twin today.... I'll post a pic in a sec
@Zombiehunta666
*lllllll*
The birth of the ZombieHunta!
http://www.jeepforum.com/forum/f22/birth-zombiehunta-1612329/
zombiehunta666 is offline
post #16887 of 30353 Old 12-17-2013, 09:33 PM
SkylarM
SkylarM is offline
post #16888 of 30353 Old 12-17-2013, 09:47 PM
Hotshot
Those tires sure went fast. Stuck them online this afternoon and the phone lit up. Lol. Sold all 5 for $400.00.
Hotshot is offline
post #16889 of 30353 Old 12-17-2013, 09:51 PM
zombiehunta666
@Zombiehunta666
*lllllll*
post #16890 of 30353 Old 12-17-2013, 09:52 PM
zombiehunta666
Originally Posted by Hotshot
Those tires sure went fast. Stuck them online this afternoon and the phone lit up. Lol. Sold all 5 for $400.00. Sent from my iPad using JeepForum
Your almost halfway to my Christmas present. Your getting close.
@Zombiehunta666
*lllllll*
roll call ORANGE COUNTY shortbussrydah California Jeep Forum 4590 12-29-2015 08:44 PM
Roll Call Ventura County blue52 California Jeep Forum 41 05-05-2013 01:02 PM
Roll cage fabricator in Orange County, Ca.? Stinkbug California Jeep Forum 6 11-29-2010 11:11 PM
Roll Call: Who's Going to Big Bear Over the 4th? roadking California Jeep Forum 12 07-07-2010 09:04 AM
Nor Cal Roll Call rugbygode2 California Jeep Forum 54 11-25-2008 11:54 PM
