Roll Call: LOS ANGELES COUNTY! - Page 1056 - JeepForum.com
 5Likes
post #15826 of 30358 Old 11-26-2013, 10:51 PM
Hotshot
Originally Posted by zombiehunta666
Bump
What size tires did the JKUR have?
Hotshot is offline
post #15827 of 30358 Old 11-26-2013, 11:09 PM
zombiehunta666
Originally Posted by hotshot
what size tires did the jkur have? Sent from my ipad using jeepforum
35
@Zombiehunta666
*lllllll*
The birth of the ZombieHunta!
http://www.jeepforum.com/forum/f22/birth-zombiehunta-1612329/
zombiehunta666 is offline
post #15828 of 30358 Old 11-26-2013, 11:17 PM
Hotshot
35
You have 35's, right? Why was it such a struggle for you? :teetertotter:
Hotshot is offline
post #15829 of 30358 Old 11-26-2013, 11:21 PM
Hotshot
I have something going on with my rear locker. Use to flip the switch the light would come on and it would lock right in. Now sometimes the light just flashes, and no lock? Need to figure that one out.
Hotshot is offline
post #15830 of 30358 Old 11-26-2013, 11:21 PM
zombiehunta666
Originally Posted by Hotshot
You have 35's, right? Why was it such a struggle for you? :teetertotter: Sent from my iPad using JeepForum
I'm much LONGER then you.
With the extra few inches on the lift I was a bit more teetee-er and was able to be pushed off unlike last time. Lmao.
@Zombiehunta666
*lllllll*
post #15831 of 30358 Old 11-26-2013, 11:23 PM
Hotshot
I'm much LONGER then you. With the extra few inches on the lift I was a bit more teetee-er and was able to be pushed off unlike last time. Lmao.
Maybe we should bolt some roller skates on our skids? Haha
Hotshot is offline
post #15832 of 30358 Old 11-26-2013, 11:28 PM
zombiehunta666
Maybe we should bolt some roller skates on our skids? Haha Sent from my iPad using JeepForum
that won't work. I'm thinking baby oil. Next time I'm gonna bring baby oil and while your getting pushed off the pebble I'll be lathering up the skid. This way once I high center I'll gun it. Should be good-to-go!
@Zombiehunta666
*lllllll*
post #15833 of 30358 Old 11-26-2013, 11:32 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Does it have a ground on the switch or relay?
Michaelgoesrawr is offline
post #15834 of 30358 Old 11-26-2013, 11:34 PM
Hotshot
That plan won't work, the tree hungers would have a kaniption fit.
Hotshot is offline
post #15835 of 30358 Old 11-26-2013, 11:36 PM
Hotshot
haven't looked at it yet. Didn't have this prob until after the TT skid was installed. Pumps were moved. I think I'm gonna have to move the pumps?
Hotshot is offline
post #15836 of 30358 Old 11-26-2013, 11:38 PM
zombiehunta666
That plan won't work, the tree hungers would have a kaniption fit. Sent from my iPad using JeepForum
I believe it's bio-degradable.
@Zombiehunta666
*lllllll*
post #15837 of 30358 Old 11-26-2013, 11:39 PM
Michaelgoesrawr
I figured they were electronic. I can't imagine the TT did anything to them specifically unless something was moved around during the install.
It's probably an easy spot once you give it a once over.
post #15838 of 30358 Old 11-26-2013, 11:39 PM
zombiehunta666
I think you need a little more mods and you'll be fine.
@Zombiehunta666
*lllllll*
post #15839 of 30358 Old 11-26-2013, 11:45 PM
Hotshot
I'd drive that.
Hotshot is offline
post #15840 of 30358 Old 11-26-2013, 11:46 PM
Hotshot
Need to make a arm that sits front to back mounted to the skid with skateboard trucks at both ends with a push pull hydraulic ram. Flip a switch one way and it lifts the front and plants the rear wheels so you can wheelie across the rocks. Flip it the other way and it lifts the rear and plants the front wheels allowing you to stink bug across the rocks. How about that plan?
Hotshot is offline
roll call ORANGE COUNTY shortbussrydah California Jeep Forum 4590 12-29-2015 08:44 PM
Roll Call Ventura County blue52 California Jeep Forum 41 05-05-2013 01:02 PM
Roll cage fabricator in Orange County, Ca.? Stinkbug California Jeep Forum 6 11-29-2010 11:11 PM
Roll Call: Who's Going to Big Bear Over the 4th? roadking California Jeep Forum 12 07-07-2010 09:04 AM
Nor Cal Roll Call rugbygode2 California Jeep Forum 54 11-25-2008 11:54 PM
