Roll Call: LOS ANGELES COUNTY! - Page 105 - JeepForum.com
 5Likes
post #1561 of 30362 Old 11-30-2011, 10:48 AM
Horaciosan
I got 33 12.5 15 tire on stock rims 4 inch lift ..now I got tire rubing what size spacers do I need
Horaciosan is offline
post #1562 of 30362 Old 11-30-2011, 10:58 AM
clg82
I have that exact same setup with NO tire rubbing issues. Where exactly are you rubbing at?
sent from my jeep.
clg82 is offline
post #1563 of 30362 Old 11-30-2011, 11:21 AM
danielbuck
1946 CJ2
when is it rubbing and where? If it's rubbing at full steering lock, you might need to adjust your steering bump stops? (just unscrew them a bit, and/or put a washer in there)
If you have stock track bars, as I understand it with 4" of lift they are probably pulling your axles to one side a good bit, causing one tire to be closer to the frame than the other. (I'm having this problem with 3" of lift) So you'll be more likely to rub on the side that's pulled inward. Time for adjustable track bars :sigh: more money. lol
danielbuck is offline
post #1564 of 30362 Old 11-30-2011, 02:06 PM
Horaciosan
The tires rub on the leaf springs..
post #1565 of 30362 Old 11-30-2011, 02:09 PM
clg82
All you have to do is remove the leaf springs and you will be good to go
clg82 is offline
post #1566 of 30362 Old 11-30-2011, 02:12 PM
danielbuck
1946 CJ2
oh, I was unaware that this was a leafspring jeep. Forget my trackbar comment then. Do leafspring jeeps even have trackbars?
How about you fill in your jeeps profile? that would help people out alot when trying to figure out problems, if they know what your jeep is and what's on it.
If it's rubbing the leafspring, then I'm guessing you need to decrease the amount that the wheels turn, or put spacers on the wheels to push them farther out? I don't know, just a guess.
post #1567 of 30362 Old 11-30-2011, 02:12 PM
Hotshot
Thats the prob right there, it has leaf springs. Just joking.
Hotshot is offline
post #1568 of 30362 Old 11-30-2011, 02:16 PM
clg82
Black0rifle (Justin) has leaf springs and he had an easier time getting up obstacles in Calico than you did
clg82 is offline
post #1569 of 30362 Old 11-30-2011, 02:24 PM
Horaciosan
I'll have to fill out my jeeps profile and tell what jeep I have next time .I'm going to pick up sum spacers from sum guy ,there only 1 inch but for 20$ ill give it a try. Thanks everyone for your help
post #1570 of 30362 Old 11-30-2011, 02:26 PM
Horaciosan
Plus leaf springs make it a real man's jeep. Just joking .
post #1571 of 30362 Old 11-30-2011, 02:31 PM
Hotshot
Try adjusting the stops like Daniel mentioned? Spacers for $20.00 sounds like smoking deal, I think I'd grab them either way.
Hotshot is offline
post #1572 of 30362 Old 11-30-2011, 02:32 PM
Hotshot
Hotshot is offline
post #1573 of 30362 Old 11-30-2011, 02:32 PM
Sancho151
1975 CJ5
2x
°llll°
Sancho151 is offline
post #1574 of 30362 Old 11-30-2011, 02:50 PM
Horaciosan
When I get home today ill look at the stops see it will help any and get the spacers . Will see what works
post #1575 of 30362 Old 11-30-2011, 04:05 PM
Hotshot
Easier time then me, yeah right, you mean a easier time then you. At least Justin and I didn't have to pull our floor board plugs after each obstacle to drain the puddles out of our jeeps like you did.
Hotshot is offline
roll call ORANGE COUNTY shortbussrydah California Jeep Forum 4590 12-29-2015 09:44 PM
Roll Call Ventura County blue52 California Jeep Forum 41 05-05-2013 02:02 PM
Roll cage fabricator in Orange County, Ca.? Stinkbug California Jeep Forum 6 11-30-2010 12:11 AM
Roll Call: Who's Going to Big Bear Over the 4th? roadking California Jeep Forum 12 07-07-2010 10:04 AM
Nor Cal Roll Call rugbygode2 California Jeep Forum 54 11-26-2008 12:54 AM
