Looking for Calico info - JeepForum.com
post #1 of 11 Old 03-14-2014, 02:24 PM Thread Starter
mattgray2702
I am familiar with the named trails at Calico (Doran, Odessa, Phillips, Mule Canyon and so on). What I am wondering is if anyone has been on the trails around Wall Street canyon. A couple of years ago, I was on the trail that connects the Wall Street Overlook area with the Doran trail (near Bismark mine). There was a large wash out on that trail at the time. Has it gotten any better recently?
Also, looking on Bing/Google maps, I see lot of trails just north and west of the Wall Street overlook. Are these passable? Challenging? One of them is here:
https://www.google.com/maps/place/34...!3m1!1s0x0:0x0
Of course I can go take a look when I am out there in a couple of weeks, but I will be with a group of 9 or 10 Jeeps and want to avoid turning around too many times in a dead end.
Finally, are there any other moderate to difficult trails in other parts of Calico worth trying? Just trying to see some different areas than the usual Doran/Odessa/Philips area.
Thanks in advance!
2000 WJ Laradeo 4.0
IRO 3" Lift Kit with adjustable track bar and Doetsch Tech upgrade
265/75/16 BFG ATs, IRO Sliders, Rola roof rack with extension
mattgray2702 is offline
post #2 of 11 Old 03-15-2014, 05:07 PM
Hotshot
Originally Posted by mattgray2702
I am familiar with the named trails at Calico (Doran, Odessa, Phillips, Mule Canyon and so on). What I am wondering is if anyone has been on the trails around Wall Street canyon. A couple of years ago, I was on the trail that connects the Wall Street Overlook area with the Doran trail (near Bismark mine). There was a large wash out on that trail at the time. Has it gotten any better recently? Also, looking on Bing/Google maps, I see lot of trails just north and west of the Wall Street overlook. Are these passable? Challenging? One of them is here: https://www.google.com/maps/place/34%C2%B057'59.6%22N+116%C2%B052'23.8%22W/@34.9660641,-116.8738221,1691m/data=!3m1!1e3!4m2!3m1!1s0x0:0x0 Of course I can go take a look when I am out there in a couple of weeks, but I will be with a group of 9 or 10 Jeeps and want to avoid turning around too many times in a dead end. Finally, are there any other moderate to difficult trails in other parts of Calico worth trying? Just trying to see some different areas than the usual Doran/Odessa/Philips area. Thanks in advance!
Wall Street over look is the trail that dead ends at the big water fall , right? How long has it been since you've been there? I think the wash area your talking about is a regular route we take to the overlook. If we're talking about the same spot?
If it's the same spot, where you turn left to go to the big waterfall dead end. If you turn right and go just a little ways there's a uphill trail to the left before you get to the narrow passage. And further north I found a trail with a tight squeeze, probably to narrow for a 4 door JK? I also found another interesting spot near there that has a interesting waterfall, it has a little cave under it, I don't think the cave would be a problem, should be able to straddle it, but this waterfall has a hard left turn going up it. I saw no tire tracks at all where I'm talking about. Both these trails would lead you back out to the trail that will take you by the rock cabin, or back to Wall Street overlook. Last trip out there I spent the first day checking a few different canyons. There's a ton of possible trails, just have to take the time to explore and map them out.
Hotshot is offline
post #3 of 11 Old 03-17-2014, 04:25 PM Thread Starter
mattgray2702
Thanks for the info. Sounds like you have really explored that area.
The washed out trail I was talking about is the one that goes from Doran directly to the Wall Street Overlook area (the dead end with the big waterfall). I was last there about a year and a half ago. It is right about here:
3457'57.2"N 11652'04.5"W
It's hard to tell from the satellite map, but I think the first trail you are suggesting might be here (the one "If you turn right and go just a little ways there's a uphill trail to the left before you get to the narrow passage").
34.965835, -116.871132
2000 WJ Laradeo 4.0
post #4 of 11 Old 03-17-2014, 05:17 PM
Hotshot
Yeah that's the wash, it's beaten down pretty good now. Just beyond the wash is a waterfall also. Both spots are fun, and not that difficult.
And yes you marked the start of the trail before the narrow passage. Directly north of where that trail drops you back onto the wall street trail is a couple more. I can see the one that I said 4 door JK's probably wouldn't make it through, just not sure how to mark it on the map for you. You can see the trail real well, it cuts off in a left curve off the wall street trail and curves to the right at first and the goes directly north.
Hotshot is offline
post #5 of 11 Old 03-18-2014, 09:42 AM Thread Starter
mattgray2702
Thanks again. We will have a mix of jeeps with 32's to 37's with 2 JK 4-doors. This area sounds like a good challenge.
To mark maps like I did, just find the thing you want to mark in Google satellite view. Single click the mouse where the pin should go. Up in the left corner there will be a search box that will say something like "San Bernadino, CA" with some map coordinates. Just click on those coordinates and it will drop a pin on that spot. Then you can copy the URL and paste it somewhere else (like here!). This is what my screen looks like after I click a spot on the map. Then just click where the yellow highlight is.
2000 WJ Laradeo 4.0
post #6 of 11 Old 03-18-2014, 09:54 AM Thread Starter
mattgray2702
After looking again at the first trail you told me about, I see there are might be two ways to go off Wall Street Canyon from that point I marked. Which one were you talking about? Here is a map with the two trails marked. I thought you meant the one with the red dot since it connects back to Wall Street Canyon. The other one looks interesting too, but takes you away from Wall Street.
2000 WJ Laradeo 4.0
post #7 of 11 Old 03-18-2014, 02:14 PM
Hotshot
The one without the yellow. The other two trails that I was talking about are even further north of here. There's some curves on Wall Street canyon trail just north of this. One of the trail start in those curves and if you look at the map it shows going into a rough looking canyon and then hooking back up with a road.
Hotshot is offline
post #8 of 11 Old 03-18-2014, 02:15 PM
Hotshot
When are you guys going out there?
Hotshot is offline
post #9 of 11 Old 03-19-2014, 08:47 AM Thread Starter
mattgray2702
We are going the weekend of the 28th. Going to dry camp somewhere off Odessa or Mule Canyon.
2000 WJ Laradeo 4.0
post #10 of 11 Old 03-19-2014, 11:24 AM
Hotshot
March, yeah we will be there also. That's the weekend of MJR's IDTT gathering.
Hotshot is offline
post #11 of 11 Old 03-23-2014, 05:38 PM Thread Starter
mattgray2702
Cool. Maybe we will see you guys. If not have fun! We will check out those trails on Saturday in the morning.
2000 WJ Laradeo 4.0
