Cougar Buttes trail run Feb 4th - Page 19 - JeepForum.com
post #271 of 285 Old 02-05-2012, 05:53 PM Thread Starter
clg82
Originally Posted by PhantomWJ View Post
Not only can it be retubed but it is also cheaper than buying a new one...cause you save on the u-joints and tbe swivel joint/ elbows since the reuse yours....I have a tom woods and a JE reel shaft...
So what do you suggest? I busted my front in half....if I get it retubed I could use it as a trail spare and just go with a TW up front....while getting the SYE and dual cardigan drive shaft.......
clg82 is offline
post #272 of 285 Old 02-05-2012, 06:35 PM
geocash
I guess it depends if you think you will trash another shaft. It is rare to twist off and even the best shaft won't allow you to land on it. The larger shafts are more for increased HP not for the bump and roll on. I would just get it re-tubed and spend the cash some where else.
geocash is offline
post #273 of 285 Old 02-05-2012, 07:27 PM
PhantomWJ
2003 WJ
I agree...get it retubed it should be less than 200...I was going to lenghten mine for about $160 at JE Reel in Pomona which is the same as getting it retubed...I'm at 6" so get a SYE was imperative because I has major vibes even with adjustable lowers and adj. Upper a-arm.... I could have had my rear shaft lenghtened for 150 but I found a 242 with tom woodz SYE and matching DS for 300...the SYE reduced the steep angle of the rear shaft and with a single- double cardain shaft my vibes were gone....
PhantomWJ is offline
post #274 of 285 Old 02-05-2012, 07:30 PM
PhantomWJ
2003 WJ
Getting it retubed and balance it shouldn't have to be a spare shaft....also make sure your lift is where you want it to be so that you have proper operating lenght...in other words don't...get your shaft fixed and the. 2 months later lift your trhcm higher....
post #275 of 285 Old 02-05-2012, 07:32 PM Thread Starter
clg82
But if I am upgrading the front with a tom woods driveshaft couldn't i just use the retubed one as a spare anyways?
clg82 is offline
post #276 of 285 Old 02-05-2012, 07:56 PM
PhantomWJ
2003 WJ
I suppose you can...if u have the cash to dump on a whole new one...but what happened to you is not the rule its an exception...plus...they can retubd it with a thicker wall tube...
post #277 of 285 Old 02-05-2012, 08:00 PM Thread Starter
clg82
Yeh i know, but I need to spend my tax return before it burns a hole in my pocket from what i've been reading the tom woods drive shafts (compared to stock) can take a beating....and im not even sure if the guy that would retube it would even be able to find something thicker.....all that aside......i have about 900 left after purchasing the new TW front driveshaft....besides getting the rear SYE with drive shaft with new savvy upper control arms.....is there anything else that my money would be better spent on? that anyone can suggest
clg82 is offline
post #278 of 285 Old 02-05-2012, 08:32 PM
PhantomWJ
2003 WJ
900 bucks can go a long way on your rig...there us a lot if aftermarket support
post #279 of 285 Old 02-06-2012, 11:21 AM
danielbuck
1946 CJ2
oh man, bummer about the driveshaft! But, sometimes ya gotta pay the piper. Rocks are indeed demanding! Hope it didn't ruin the whole tip.
danielbuck is offline
post #280 of 285 Old 02-07-2012, 09:24 AM
qewbawl
Bummer you busted your driveshaft, Chris! Look on the bright side, now you have an excuse to spend some money on your rig
qewbawl is offline
post #281 of 285 Old 02-07-2012, 10:19 AM
PhantomWJ
2003 WJ
Its more fun to spend money to improve and upgrade your rig than it is to replace parts...
Have you considered buying a used shaft?
post #282 of 285 Old 02-07-2012, 10:39 AM
gactech
1st day at KOH. Guess I'm glad I found it at my buddies house rather than out on the lakebed. Trip back to yucca planned today. FFS
gactech is offline
post #283 of 285 Old 02-07-2012, 11:01 AM
Hotshot
What is that the radiator drain plug leaking?
Hotshot is offline
post #284 of 285 Old 02-08-2012, 10:09 AM
gactech
Zj
Yes Hotshot. A few calls to Yucca and carquest had it for 7 dollars. Should be out on the lake bed by 10 to watch the Quals
gactech is offline
post #285 of 285 Old 02-08-2012, 11:03 AM
Hotshot
Cool, glad to hear it wasn't anything serious.
Hotshot is offline
Go pro cam at cougar buttes suzukisailor315 California Jeep Forum 2 11-28-2011 11:31 AM
Trail blazing north east of Cougar buttes in JV open offroad area aw12345 California Jeep Forum 1 05-29-2011 05:11 PM
Second annual Cougar Buttes Night run aw12345 California Jeep Forum 2 08-29-2010 04:52 PM
Trail report for Miller Jeep trail, anyone? 1sportsdoc California Jeep Forum 3 08-27-2010 05:11 PM
JV Cougar Buttes Trails cvd California Jeep Forum 1 04-12-2010 02:41 AM
