Big Bear - Chains needed? - JeepForum.com
post #1 of 7 Old 12-28-2012, 04:45 PM Thread Starter
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
Hey guys, I'm making a trip up to Big Bear in Feb. I've gone up to Mammoth before, never needed to use them. Just wanted to see if its ever gone to a Level 3 status (All vehicles including 4x4's require chains). I see a lot of time its at level 2, which I'd be safe with my A/T's. Just wanted to know if its worth investing in a set of chains, and if so, both axles or just front or back?
I'm running BFG 285's on my 2010 Wrangler Sport.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #2 of 7 Old 12-28-2012, 07:29 PM
bananaslug
My uneducated guess, is that they will only require them if its really coming down. And if so, youll probably want chains regardless because you are driving on a windy mountain shelf road.
bananaslug is offline
post #3 of 7 Old 12-29-2012, 12:00 PM
johngf40
I am a Big Bear resident. I have not seen an R3 up here in the last two years. However, current law is that 4WD vehicles must carry chains even in an R2 situation.
johngf40 is offline
post #4 of 7 Old 12-31-2012, 12:08 AM
Xtremegameroom
You do have to carry chains. Whether you need to put them on or not, you still need to carry them. There is a checkpoint near snow valley where the sherrif checks to see if you have chains.
Chains only run about 80 bucks a set (for my excursions 35's) so it's not too bad. And i think you only need 1 set.
Xtremegameroom is offline
post #5 of 7 Old 12-31-2012, 11:18 AM
sandman92k
I was there yesturday, let me put it this way if you do not have a four wheel drive with the proper tires do not go with out the chains, it took me almost 3 hours to get down the back side towards lucerne becuase of all the idiots in vehicles without chains or four wheel drive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sandman92k is offline
post #6 of 7 Old 12-31-2012, 12:34 PM Thread Starter
MusicMaverick
2014 JK Wrangler
Thanks guys... Maybe I'll pick up a set just to have them in that case... Can't hurt...
Currently: '14 JKU
post #7 of 7 Old 01-07-2013, 07:02 PM
TJ-Tera
Good info guys...going there at the beginning of Feb for my g/f birthday and will be buying a set before then. Thanks!
TJ-Tera is offline
