Any Wrangler wrenchers in the victorville/apple valley area ???? - JeepForum.com
post #1 of 5 Old 02-16-2013, 08:42 PM Thread Starter
88joker88
just got a 88 yj with an extremely low mileage 99 4.0 & 5 speed swap that's only 85% done ...
anybody around here that knows there way around a jeep blindfolded want to come point me in the right direction or help me wrench ?
HAVE CASH $$$
I have above average wrenching skills but have never owned a jeep.
Needs the rest of the wiring figured out.
Needs Rear drive shaft altered for the slip yolk eliminator.
Needs Front Drive shaft installed.
Needs the 99 Tank installed "i think"
needs 99 ignition installed "i think"
fuel lines ran
4x4 shifter installed "might need a different one"
Can do some of it myself but could definitely use someone who knows what they are looking at's help.
Thanks Guys!
88joker88 is offline
post #2 of 5 Old 02-19-2013, 05:56 PM Thread Starter
88joker88
nobody around here that knows their way around a wrangler that wants to help me out and make some extra cash huh?
post #3 of 5 Old 02-21-2013, 05:18 AM
DaK09
Check here, local club in your area.
http://victorvalley4wheelers.com/smf/index.php
Wheeled with them a few times. Good people. Had some YJ's on the run.
DaK09 is offline
post #4 of 5 Old 02-21-2013, 08:48 AM Thread Starter
88joker88
thanks!
post #5 of 5 Old 03-16-2013, 02:08 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Man. I'm out in Phelan and I wish I could help. If you were doing YJ drivetrain stuff I might be able to. lol. Although the front driveshaft should be simple. Could just be a matter of getting new u-joints to match the new t-case. And you should be able to use the existing fuel rails, just plumb them from the tank and then to the FI on the motor with the correct fittings.
If your t-case has a slip yolk eliminator already, you don't modify the rear drive shaft you buy a new one. Try here http://www.4xshaft.com/ really good company.
Edit: I was browsing the other site and noticed you have the tank up for free. Is it the plastic one?
Michaelgoesrawr is offline
