Opinions on Full Width Axles in WA - JeepForum.com
post #1 of 7 Old 11-27-2013, 04:09 PM Thread Starter
Sasquatch4x4
thinking of 1 tons (d60/14bolt combo) on my YJ and i'm trying to avoid narrowing axles for a variety of reasons. only worry is width restrictions on trails. anybody running full width or extra wide axles in Washington? what kind of troubles have you come across?
Also if you are, whats the overall width you're running? thanks for the input!
Check Out My YJ Build and Give me Advice!! : http://www.jeepforum.com/forum/f22/blue-95-yj-built-college-kid-w-part-time-job-1428767/
Sasquatch4x4 is offline
post #2 of 7 Old 11-27-2013, 08:48 PM
tjcj
My brother had 14/60 on his 48 Willy's. It was right around 82" outside to outside of 37" MTR's. A lot of the trails he could follow just had to pick the right lines or get real creative turning in the tight trails around Little Naches / Rimrock.
Sent from my XT881freeze ray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is online now
post #3 of 7 Old 11-27-2013, 09:42 PM
1982cj8
Evans Creek has gatekeepers set at I think 78" on all trails.
Always bring a compass, it is awkward to have to eat your friends.
4X4XNORTHWEST.COM
1982cj8 is offline
post #4 of 7 Old 12-02-2013, 12:25 PM
redjeepguy1
There's a number of trails in the Naches area that are too narrow for full size truck axles as well.
Bill
member 141,234,541 of the red jeep club
redjeepguy1 is offline
post #5 of 7 Old 12-11-2013, 09:02 PM
RaggedOleMan
PNW trails are not for wide rigs, unless of course exiting on to the main road looking like a bent up pop can is on the menu, or getting towed out is... PNW trails can, more often than not, be tight and technical and muddy and snowy and rocky. Traction is usually not an option, save for a day in August at Manastash. And, a heavy foot on the gas pedal will only help drain your gas tank, and bank account. Think finesse & skill and patience, or give in to 4% beer, 12% wine of 100% proof courage, and then be ready to pay the tab. It is what it is.
RaggedOleMan is offline
post #6 of 7 Old 12-11-2013, 09:45 PM
mudb8
want it rite or rite now?
mudb8's Avatar
Never measured it, the tires stick out an inch beyond the bushwackers with hummer wheels, 1.5" spacers to clear the ford brakes and high steer arm. Waggy 2" springs front and rear. Moved the frame mounts for the front to center it up and made hoops.The rear practically bolted in, just made rear shackles and shock towers. 12" travel front and rear. Customer wanted it big and functional...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #7 of 7 Old 12-12-2013, 08:36 PM
RaggedOleMan
Very nice....
