Evan's Creek GPS Mapping for a New Trail Map - JeepForum.com
post #1 of 11 Old 11-18-2008, 02:51 PM Thread Starter
lupinsea
lupinsea's Avatar
Hey guys. . . just posted this in the Trip Reports section. Thought I'd mention it here, too.
I've started work on creating a new trail map of Evan's Creek ORV park. It'll be similar to the Reiter Trails Map I did a few months ago in terms of look and quality when it's done.
So far I was able to GPS map all the trails there on November 15th in one day. Here's the trails as they were recorded. One or two obvious glitches but otherwise the data is very accurate. With a new auxillary GPS antenna the signal reception was boosted 3-5 time over normal. Even in the deepest tree cover I was picking a ton of solid signals. At times the accuracy hit 5 ft +/-.
- Jay
lupinsea is offline
post #2 of 11 Old 11-18-2008, 03:33 PM
deltabravo
What make/model GPS do you use?
deltabravo is offline
post #3 of 11 Old 11-18-2008, 04:23 PM
yyoon
Hey, it was good to see you. Good work!
6" FT LA, 315/75R16 MT/R's, AntiRock, FT Rear sway, Rockhard rear bumper/tire carrier w/frame kit, some other trinkets.
yyoon is offline
post #4 of 11 Old 11-19-2008, 09:15 AM
L&R Jeeper
X2
Can't wait to see it, I need a good Evans map.
31 muds, 500lbs winch, 1" lift, tow straps, first aid kit, fire extinguisher, axe, shovel and...?
L&R Jeeper is offline
post #5 of 11 Old 11-19-2008, 12:27 PM Thread Starter
lupinsea
lupinsea's Avatar
My GPS Setup:
  • Garmin GSP60 reciever
  • Plug-in cig adapter for power + battery back up for when the engine is off
  • Gilsson MCX auxillary antenna mounted on hood.
  • National Geographic TOPO! mapping software.
Garmin GPS 60
When shopping for a GPS receiver about 2+ years ago I just wanted something to map the trails. I already knew where I was going so I just wanted a recorder, pretty much. The GPS 60 was the cheapest I could find that had a good built-in antenna, and the WAAS stuff to help refine the signal and it also interfaced with my Mac. I could turn it on, run the trail, then hit record. Very simple and straight forward. I really didn't want a lot of features. Also, being that it's hand held I can take it with me outside of the Jeep easily. That said, if I were to get another one I wouldn't mind a color screen and ability to load topo maps onto the unit. Garmin has some other GPS60 series units that have more features and I'd look at those.
As nice as the GPS 60 is, it's compromised by the need for the small built-in antenna. Factor in the fact I didn't have a good mounting spot (I had it dangling from my rear view mirror) AND the dense tree cover in the NW and signal reception was a bit of a problem. On the Reiter run there'd be some significant gaps in signal coverage. Not a big enough problem but it was there.
Gilsson MCX Auxillary Antenna
Wow. HUGE FREAK'N DIFFERENCE in signal strength. This antenna gives similar performance to Garmin's own external antennas but it retails for ~$23 instead of Garmin's $99. It was simply amazing how much the signal improved with the use of the antenna. I figured I was getting at minimum of 3 times better reception and probably averaged 5-6 times improved reception. Before I'd get strong but partial signal on 2-3 satellites and maybe a full-bar signal on another. With the Gilsson antenna I'd get 5-6 full solid bars of reception and another 2-3 very strong partial signals. It'd also take just a fraction of the time to pick up the satellites that without the antenna.
Also, the antenna has a 9 ft wire and magnetic base. I was able to stick it on the hood where it had an unrestricted view up from the Jeep. This also let me stick the GPS 60 receiver in my cup holder where it was significantly more secured and much less annoying. The antenna cable was thin enough to run through the weather stripping on the passenger door.
National Geographic TOPO! Software
What can I say. . . it works. But it's very clunky. I like that is uses the 7.5' USGS base maps and that you can turn shading on for improve map readability (helps define the contours and land shape). But the software tools really suck and are difficult to work with. I've found work-arounds to speed up and ease the use of the software but it's just poorly designed. Unfortunately, it's the only software that I know of (at least at the time I bought it) that works on the Mac platform.
For the Reiter Map (and what I'll do for the Evan's Creek map) is import the GPS data into TOPO! to get the trails mapped out over the base raster map images. Then I'll re-trace the routes if needed to clean them up and get continuous trail routes (instead of cut up into separate sections we ran at different times). Finally, I'll select all the trails and change their line colors to what I want. And I'll generate some extra content such as the elevation profiles, note trail milages, and any 3D perspective views. All this gets exported into Photoshop where the final map is composed. Icons added, text written, borders drawn, titles typed, etc.
- Jay
lupinsea is offline
post #6 of 11 Old 11-28-2008, 07:45 PM
CrazyWalnut13
Cool thanks!!
Do you think Evan's Creek is still drivable? I'm only here for another 2 days and I would love to go down there with my dad.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #7 of 11 Old 04-30-2010, 04:26 PM
FlyingJeep
2009 JK Wrangler
Nice work... a little bump for prosperity sake.
I hope you can finish an Evans Creek map like what you did for Reiter.
2009 JK Unlimited Rubicon - Deep Water Blue - AEV 3.5" Premium Lift - 35" KM2's
Previous Jeeps:
--1998 TJ Sport 4.0L - Gunmetal Blue '01-'09
--1997 TJ S 2.5L - Lapis Blue '96-'00
--1975 Jeep Wagoneer - Blue '93-'95'
FlyingJeep is offline
post #8 of 11 Old 05-06-2010, 02:28 PM Thread Starter
lupinsea
lupinsea's Avatar
Oh yeah. . . the map.
Forgot. . . I finished that about a week ago. Mostly had to do a color check before saving as a PDF for download. The greens and blues for the trails look a little "bright" on screen but they should print out just right (not too dark). It's a big file, about 36 MB. But it's now available.
For a direct link to the PDF, click here.
To see my Evan's Creek Trail page, click here.
Like the other maps available from my website, this one is designed to be printed double-sided on 11x17 inch paper. If you don't have access to that kind of printer, either set your print option to "scale to fit page" or take it in to an Office Depot, Kinkos, or other print shop. For about $2 they'll print it out in color on 11x17. Another ~$2 and they will laminate the page for you so it is more durable. This is what I do to all my maps I print up and they hold up great for year and years in the Jeep on the trail in the rain and mud. Well worth it to get it laminated.
Sorry for the looooooonnnnng delay guys. Enjoy the map. Here are some smaller pre-view shots of the front and back. For best quality, of course, download the PDF from the link above.
Front of Map
Back of Map
- Jay
lupinsea is offline
post #9 of 11 Old 05-25-2010, 11:32 PM
PhilipJ
PhilipJ's Avatar
Links are broken.
Nice to see my old YJ made it into the pics though.
PhilipJ is offline
post #10 of 11 Old 05-26-2010, 12:00 PM Thread Starter
lupinsea
lupinsea's Avatar
Yeah, I need to pay the hosting fee for the next year. Gotta wait until next pay day which is in a week. Check back June 2nd or 3rd and they'll be back up.
- Jay
lupinsea is offline
post #11 of 11 Old 04-27-2012, 11:35 AM
SkawtNW
This map is great, thanks for making it available!
SkawtNW is offline
Evan's Creek this Sunday the 10th JIBTEXHNKA Washington Jeep Forum 15 01-17-2010 08:16 PM
Shoe Creek Trail Ride? EvilWJ02 South East USA 4 09-09-2009 02:54 PM
Evan's Creek 8/1? Tradesman300 Washington Jeep Forum 3 07-30-2009 04:18 PM
Evan's Creek this saturday (July 11) JIBTEXHNKA Washington Jeep Forum 8 07-14-2009 03:05 PM
Fordyce Creek Trail 2000TJDude California Jeep Forum 3 05-19-2008 10:52 AM
