1979 ford to jeep swap - JeepForum.com
post #1 of 3 Old 03-08-2014, 10:26 PM Thread Starter
alaskageo
Yj 1979 ford to jeep swap
Hello All new to posting so be easy on me. I have a 1990 jeep yj I am currently taking down to the frame and doing a full overhaul on. I also just picked up a 1979 ford f150 and I'm looking to use as much stuff off it as I can the ford has the transmission I need NP-435 a 302 motor (actually comes with an extra 302) and it comes with a 9 in lift. what are so key things to look into when swapping the axles with the lift. I know the front will have to be converted from leaf spring to coil and thats awesome, but I've never done that operation before. Thanks for the help in advance.
alaskageo is offline
post #2 of 3 Old 04-01-2014, 07:17 PM
MPjeeper
2011 JK Wrangler
Interesting... Lets see some pictures of what your are working with.
11 JKU Rubi - http://www.jeepforum.com/forum/f22/alaska-night-crawler-2246225/
MPjeeper is offline
post #3 of 3 Old 04-01-2014, 07:25 PM
MPjeeper
2011 JK Wrangler
Front axle, pinion Drop side from your transfer case" If you plan and going to coils from leaf spring.. ensure control arms wont make contact with driveshaft or the frame" , Axle Gear ratio to tire size you plan on using, Axle width. just some of the things. 9inches of lift is alot for a jeep. my 2cent.
MPjeeper is offline
