from zj to wj - JeepForum.com
post #1 of 9 Old 05-17-2011, 06:33 PM Thread Starter
thestig_wj
from zj to wj
I know some guys have put zj front DS in wj with 4in lift and it works...my question is can I take the yokes (from front axle and tcase) off a 98 zj and put them on 00 my wj both have 242....will it work....I know zj has HP D30 but are the yokes different also will the OD unit from zj work in wj I know about the cut-off year for that sensor so I may not have OD but other than that will it work
thestig_wj is offline
post #2 of 9 Old 05-17-2011, 06:51 PM
AGDubyaJ
no, you have to get a T-case yoke from a WJ. different spline count i believe. hit up carolina driveshaft or tomwoods... a yoke will run you about $80. you CAN use the pinion yoke from any D30 though. not sure about the OD sensor... probably not.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #3 of 9 Old 05-17-2011, 07:06 PM Thread Starter
thestig_wj
Yea spline count was my biggest concern as far as OD unit I thought that they changed the 42re in 97 or 98 and it was the same one they used in the first few years of the wj until they went to the 44re...anyone know for sure
post #4 of 9 Old 05-17-2011, 07:49 PM
AGDubyaJ
if you have a 4.0L you have a 42RE. it was the only trans put behind the 4.0L in the WJ platform. not sure on change over years though.
AGDubyaJ is offline
post #5 of 9 Old 05-17-2011, 07:59 PM Thread Starter
thestig_wj
Sorry was suppose to say the new 42re cuz I'm pretty sure they changed something with OD sensor
post #6 of 9 Old 05-17-2011, 08:29 PM
AGDubyaJ
yes, i believe they did change something with the OD unit, hopefully someone will chime in who knows what they are talking about.
AGDubyaJ is offline
post #7 of 9 Old 05-17-2011, 08:35 PM Thread Starter
thestig_wj
Ok thanks I thought they did
post #8 of 9 Old 05-18-2011, 12:12 PM
1AAdam
from what i understand it was a programming thing because u can have an older trans flashed and the revs at 70mph will go from 2200 to 2000. any idea how much a flash would cost?
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #9 of 9 Old 05-18-2011, 09:17 PM
narnwv
narnwv's Avatar
I thought that was only the 45rfe becoming the (5)45rfe in the V8.
~Aaron
narnwv is offline
