Are you strong enough to install cylinder head? I am not. - JeepForum.com
post #1 of 10 Old 05-01-2013, 07:31 AM Thread Starter
car5car
2002 M-38
I installed it in XJ, but couldn't in WJ, had to use lift.
01 XJ 2wd 4.0
car5car is offline
post #2 of 10 Old 05-01-2013, 07:35 AM
ChrisHager
Administrator
ChrisHager's Avatar
I removed/installed my cylinder head by hand with the intake and exhaust manifolds attached. I'll have to say using a lift would be much safer!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #3 of 10 Old 05-01-2013, 07:42 AM
PeteYJTJ
Great idea -- that's what lifts are for. Why wreck your back? I use mine to install/remove my hardtops off mySWB Jeeps.
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #4 of 10 Old 05-01-2013, 06:38 PM
FlyRLo
Um...ya... I just carried my bare block 340 to the bedroom and put it in the closet when I got it back from the machine shop...hey but safety first!
FlyRLo is offline
post #5 of 10 Old 05-01-2013, 11:05 PM
99WJ539918
Wuss...
... as I'm looking at the hoist...
99WJ539918 is offline
post #6 of 10 Old 05-02-2013, 12:35 AM
MEinSoCal
yup, i did and my Jeep even had a 3in lift. iirc, the I6 head weight about 75-80lbs. it wasn't easy or fun, but i was able to R&R without a hoist or a helping hand
MEinSoCal is offline
post #7 of 10 Old 05-02-2013, 03:10 AM
cykaaro
Better than screwing your back, or if you have a bad back already. Back injuries suck ***. (mine's been screwed since I was in my 20's)
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #8 of 10 Old 05-03-2013, 05:42 AM
dave01
I use my hoist to lift the spark plugs out...
dave01 is offline
post #9 of 10 Old 05-03-2013, 05:47 AM
veiri86
2003 WJ
LMFAO
Dude; You really made me laugh
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #10 of 10 Old 05-03-2013, 08:49 AM
99WJ01TJ
I've donme it on my TJ but i have the luxury of the hood that opens all the way and rest' on the windshield & flat fenders to stand on(3" lift), i wouldn't even want to try it on a WJ. My WJ's 4.7 heads are light....but boy is the passenger side ever so crammed in there
99WJ01TJ is offline
