Yoke removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Yoke removal
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 07-14-2012, 10:23 PM   #1
kaotickustums91
kaotickustums91's Avatar
Yoke removal
Can someone give me a write up on removing yoke from front axle and 247 transfer case I have the cv type but I picked up both yokes and double cardon drive shaft today for 40 bucks just waitin to put them on mine lol
kaotickustums91 is offline   Reply With Quote
Unread 07-15-2012, 01:02 AM   #2
Supertrooper50
Air, impact gun, thread lock, torque wrench, pry bar or hammer works on them
Supertrooper50 is offline   Reply With Quote
Unread 07-15-2012, 02:11 AM   #3
the88thpianoman
the88thpianoman's Avatar
2003 WJ
Getting the yokes off is the easy part. Getting them back on is a little more involved. The transfer case side isn't too bad; just use a torque wrench to set it to 90-130 ft/lbs. The axle side is a bit more involved, and doing it wrong can wreck the diff.
WJ front drive shaft and fuse panel for sale
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
Unread 07-15-2012, 02:13 AM   #4
Supertrooper50
My axels are shimmed from my 4.56 so I just torque em down,
Unread 07-15-2012, 07:54 AM   #5
kaotickustums91
I know the transfer case doesn't look bad just that one bolt on the front from what I can see but the axle side do I have to remove the differentials in order to take the time out ?
Unread 07-15-2012, 10:06 AM   #6
AndyL
either drain the transfer case or be ready to have fluid all over you during the process. The front axle yoke comes off easy enough, when you install the new one and nut, be sure to torque it to the same amount the old one was. If you over torque it, you will further compress the crush sleeve and cause pinion bearing problems, not enough torque will also cause you problems.
You might want to get a new crush sleeve and pinion seal. Do you own a torque wrench?
AndyL is offline   Reply With Quote
Unread 07-15-2012, 04:39 PM   #7
kaotickustums91
Yes. So I dont have to open the differentials
Unread 07-15-2012, 04:54 PM   #8
AndyL
If that's a question, no. And were talking about one differential.
Unread 07-15-2012, 05:13 PM   #9
kaotickustums91
I was just wondering cause someone had told me I had to drop the transfer case and remove the differentials from the front axle but now it's lookin pretty simple to do probably gonna be doin this over the weekend
