Yet another Gear thread! 32"33" tires. - JeepForum.com
post #1 of 12 Old 03-30-2010, 10:51 AM Thread Starter
Max78
1992 XJ Cherokee
Ok guys,
My front and rear axles are in need of a rebuild. Wheel bearings are shot and I think I managed to get water in them. So Iím on here posting yet another gear thread. Iím going to be spending $1431 to rebuild my axles and I want opinions and suggestions before I go through with it.
I have the 4.7 MPIF V8, 545RFE trans, 242HD TC.
I currently have 32Ē tires on my WJ with 80% tread, and I donít plan on buying a new set any time soon. When I do buy new tires, I plan on going to a 33Ē tire.
Here is what I have found out so far.
29Ē with 3.73 @ 75 = 2,171rpm (Stock)
32Ē with 3.73 @ 75 = 1,968rpm
32Ē with 4.10 @ 75 = 2,163rpm
32Ē with 4.56 @ 75 = 2,405rpm
33Ē with 4.10 @ 75 = 2,097rpm
33Ē with 4.56 @ 75 = 2,333rpm
I read allot that people say 3.73 to 4.10 is not worth it. I agree, but I take the freeway every day to work and donít like the idea of 2,400rpm. But then again I would love the quick get up and go I would get with the deeper gears. I plan on adding body armor, bumpers, roof rack, and the likes to it someday. So I would want the deeper gears for the added weight. But Iím still not too sure. I never tow anything, Donít go on long trips to often.
Right now Iím leaning towards the 4.56 gears. I just want some people to throw their opinions out there, as well as share their experiences. $1,431 is allot of money to me. I donít want to invest in something Iím not going to be happy with.
92 Cherokee - All nude and in need of some tlc!
Max78 is offline
post #2 of 12 Old 03-30-2010, 11:29 AM
rustynail
If you go with 4:10's your rpm's will be slightly lower than stock gears and tires yet you'll be turning heavier tires and in the future adding heavy bumpers, etc. My vote is 4:56
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #3 of 12 Old 03-30-2010, 12:25 PM
Planetcat
2010 WK
I agree....
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #4 of 12 Old 03-30-2010, 01:26 PM
CostcoPizza
Fresh Baked
CostcoPizza's Avatar
4:56's and slow down a bit.
CostcoPizza is offline
post #5 of 12 Old 03-30-2010, 02:03 PM
MoonyJohn
MoonyJohn's Avatar
I vote 4.56 only because you will be upgrading to 33's later down the road. Just slow it down on the freeways.
MoonyJohn is offline
post #6 of 12 Old 03-30-2010, 02:15 PM Thread Starter
Max78
1992 XJ Cherokee
I like to go the speed limit at least (75). But from the looks of it I'm more and more likely going to go with the 4.56 and just stay in the slow lane :\
Max78 is offline
post #7 of 12 Old 03-30-2010, 02:19 PM
rugermack
That can be scary on I-10 in rush hour traffic.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #8 of 12 Old 03-30-2010, 02:29 PM
Planetcat
2010 WK
You should be fine tach'ing 2300-2500 on the highway. It's no different than someone who drives their stock jeep 80-85 mph on a regular basis. My XJ w/4.56's and 32's tach'ed 2800 on the highway for many years with no problems.
post #9 of 12 Old 03-30-2010, 02:38 PM Thread Starter
Max78
1992 XJ Cherokee
Some days it crawls some days it flies. . . I like being able to do the speed limit when possible.
Max78 is offline
post #10 of 12 Old 03-30-2010, 03:00 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
4.56
You could certainly get away with 4.10's since you have the 4.7L, but I am willing to bet you'll want a bigger tire one day and thus 4.56's would be more appropriate when the time comes.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #11 of 12 Old 03-30-2010, 03:03 PM
VanBCguy
Personally, I'd go 33" with 4.56 gears. It's a good gear ratio with 33's for RPM's and fuel mileage. Plus it would even allow you to grow in tire size if wanted/needed. The old credo applies: "Do it once and do it right". But that's just my
Before you make a decision, this thead has some very interesting information in it about RPM's and tire size. Particularly those from Imped.
http://www.jeepforum.com/forum/f9/be...leage-1000765/
VanBCguy is offline
post #12 of 12 Old 03-30-2010, 03:53 PM Thread Starter
Max78
1992 XJ Cherokee
Thank you for that link.
Max78 is offline
3.73 , 4.10 , 4.56 , gears , grand cherokee
My Engine Swap "build thread" 4.0 - 5.2 redhatman ZJ Grand Cherokee Forum 52 06-30-2014 09:18 PM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
Another "clunk" thread - ignore the noise? (2004 WJ) JustSomeDude ZJ Grand Cherokee Forum 5 03-30-2009 10:15 AM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
15" with 4.5" backspace and 12.5" wide 33" tires. Rub? bjl95mustang ZJ Grand Cherokee Forum 6 05-07-2008 09:32 AM
