Wrong Oil? - JeepForum.com
post #1 of 4 Old 04-10-2011, 07:43 PM Thread Starter
TedderX_
Wrong Oil?
I'm trying to help a friend and I don't know much about GC's.
He says he has a 2001 WJ, straight six, and it's an auto.
When the Jeep is running for awhile, he feels like the oil starts running thin(loses it's consistency).
What should I tell him to do or look at or possibly run a different type of oil?
Thanks guys.
-Tedder
TedderX_ is offline
post #2 of 4 Old 04-10-2011, 09:16 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
What makes him "feel like the oil is thin"? That is the least concrete statement I've seen on here in a while. The engine in his WJ is identical to that in your Wrangler, so you know plenty.
If the motor maintains pressure at rate approximately 10psi per 1000rpm when warm, there's no need to change viscosity. 4.0s like a high-zinc oil which can be hard to find. Stick with 10W-30 viscosity and look for API "SL" rated oils. My personal favorite in my 4.0 is Mobil1 High Mileage 10W-30 which runs smoothly and yields good wear numbers with a 6000 mile oil change interval.
If he wants to really know what is going on with his oil, then get a used oil analysis from somewhere like Blackstone labs. They will analyze it for wear metals, coolant contamination, viscosity, and TBN remaining to determine if the oil and engine are in good condition.
~Richard
billzcat1 is offline
post #3 of 4 Old 05-19-2011, 12:40 PM
KayCeeJeep
The recommended weight for the 4.0 is 10w30 and they run fantastic on it. I wonder if your friend could be running 5w30, I tried it once and drained it after a couple weeks. Engine was loud once it got warmed up and I didn't think ran as well either.
Like Bilzcat1 mentioned the 4.0's like the older additive packages. I am running Rotella 10w30, but anything in a high mileage forumula and not labeled "Resource Conserving" on the API donut is much more likely to be friendlier to the 4.0. Valvoline Max Life High Mileage is very common, not very expensive and has a great add pack for the 4.0, if you want synthetic the M1 HM bilzcat mentioned would be hard to beat.
KayCeeJeep is offline
post #4 of 4 Old 05-19-2011, 12:43 PM
Apollo21
I'm gonna jump on the AMSOIL train and tell your friend to do that. They have a special formula for the 4.0 Josh runs it.
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
Not sure whats wrong??? MadDogXJ WJ Grand Cherokee Forum 11 05-21-2011 12:26 AM
I think I did it wrong... HALP!!! gbauer WJ Grand Cherokee Forum 31 03-23-2011 11:06 PM
Wrong Cat WJ-S51190 WJ Grand Cherokee Forum 11 03-16-2011 07:59 PM
know its the wrong forum coralman WJ Grand Cherokee Forum 6 10-03-2010 06:25 AM
Something is wrong!!! PuddlePirate10 WJ Grand Cherokee Forum 12 09-21-2010 09:47 AM
