Write up: WJ steering box re-seal and tap for hydro assist - Page 2 - JeepForum.com
post #16 of 23 Old 07-11-2013, 06:55 PM
Turbozcs2003
Is this box out of one with 4.0?
are they all the same?
What fails in them, just start leaking? What mileage do they start having issues?
My 02 has the cooler and the hydraulic fan, I change the fluid in it yearly.
Turbozcs2003 is offline
post #17 of 23 Old 07-11-2013, 08:05 PM
coopdc78
Great information here. Thanks for the write up. I was planning on doing my seals as well. This will be very helpful.
2004 overland 4"long arm lift
2005 wk stock
2000 camaro ss/slp w/10,000 miles
coopdc78 is offline
post #18 of 23 Old 07-19-2013, 08:10 AM Thread Starter
TJSWJ
Originally Posted by AgitatedPancake View Post
This is a great writeup! Very useful when diving into the steering boxes, just for making sure you keep everything straight
One thing I will make a note on, I do not believe that bearing belongs on the end of the worm shaft but fell into that position behind the nut when you twisted things too far and had a few bearings fall out. When I disassembled the one I just rebuilt it had a full 24 ball bearings within the worm drive, 12 silver and 12 black. At one point when I was reassembling I had a ball bearing fall within the housing and thought I lost it, it ended up nestled into the end of the worm shaft just like yours, but mine was silver. Considering the ball bearings follow a continuous loop, you need an equal amount of silver and black ball bearings to keep it alternating throughout. Somewhere within your worm drive loop you're missing a black ball bearing and have two silver bearings stacked together
Winner winner chicken dinner! I pulled another box apart last night being extra careful not sping the worm gear out. I pulled the cap off the end of the piston assembly and sure enough, there was no ball at the end. Looks like Ill be pulling my box back apart (good thing its not installed yet). Ive edited the post accordingly. Good looking out!
TJSWJ is offline
post #19 of 23 Old 07-19-2013, 08:12 AM Thread Starter
TJSWJ
yes, they are all the same. Usually they just start leaking, occasionally they need adjusted. No certain mileage that im aware of. My original box has 180k on it and I have had no issues.
TJSWJ is offline
post #20 of 23 Old 03-16-2015, 10:33 AM
timberwolffxdl
I apologize for commenting on a nearly 2 year old write up, but thought I should mention in Step 10, you say to measure 3/8" but the tape measure shows 3/4". I'm sure it was just a typo, but thought maybe it should be corrected so as new folks find the write-up (like I did) there won't be any confusion. Not everyone is adept at reading a tape measure these days and may go simply by the text without comparing it to the pictures
Nice article though, I will be referencing it to reseal my gear box!
timberwolffxdl is offline
post #21 of 23 Old 02-26-2016, 05:57 AM
oakleymx4
I don't think this ever made to the faq. I think it should be there I've been searching for a year and a half for something like this.
oakleymx4 is offline
post #22 of 23 Old 02-26-2016, 07:22 AM
ChrisHager
Administrator
ChrisHager's Avatar
Done!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #23 of 23 Old 02-26-2016, 07:42 AM
TheHoneyBadger
Great job!!!!!
TheHoneyBadger is offline
