Wont Start 1st Time - JeepForum.com
post #1 of 21 Old 01-09-2013, 10:57 AM Thread Starter
bobknott
Wont Start 1st Time
Hi All
My 3.1TD has developed a peculiar habit. I wait until the heater plug light goes out & when I try to start the engine it is dead (Absolutely nothing happens). However when I try for a second time, she fires up without any issues.
It has to be an electrical gremlin, but where? Any suggestions gratefully received.
bobknott is offline
post #2 of 21 Old 01-09-2013, 11:13 AM
4Tom
Battery terminals are best place to start
Make sure the mating surface with battery poles is clean use fine sand paper if needed and that they are tight
WJ 2001 3.1TD
Tom
4Tom is offline
post #3 of 21 Old 01-10-2013, 08:39 AM Thread Starter
bobknott
Cheers Tom. I will check it out.
bobknott is offline
post #4 of 21 Old 01-15-2013, 03:33 PM Thread Starter
bobknott
Well done Tom! Checked & cleaned my battery terminals. Although they didn't seem bad, wow what a transformation! Many thanks for the tip
bobknott is offline
post #5 of 21 Old 01-26-2013, 11:06 AM Thread Starter
bobknott
Well my problem returned again. I charged the battery for a couple of hours & noted she is taking a high charging current. Then had to pop out, but still temperamental. Wondering if its the battery dying. Any thoughts anyone? By the way terminals are clean with a liberal coating of copper ease on them.
bobknott is offline
post #6 of 21 Old 01-26-2013, 11:43 AM
4Tom
Battery could be going bad.
Most auto shop's should be able to test battery free of charge.
WJ 2001 3.1TD
Tom
4Tom is offline
post #7 of 21 Old 01-26-2013, 11:57 AM Thread Starter
bobknott
Cheers Tom. Will let you know tomorrow
bobknott is offline
post #8 of 21 Old 01-26-2013, 12:30 PM
4Tom
Hopefully new battery will sort it.
I presume the battery went flat when it wasn't been use if so its not holding a charge and alternator is probably ok.
If volt gauge on display was close to 14 v when engine is running alternator should be good.
WJ 2001 3.1TD
Tom
4Tom is offline
post #9 of 21 Old 01-26-2013, 01:00 PM Thread Starter
bobknott
It's not that the battery is flat but when you turn the ignition nothing happens. The display lights on the heating controls go out as you turn the key, but there are no clicks or clunks from the solenoid, then after a few turns of the key she starts normally. Cleaning the terminals on the battery seemed to help & so did the copper paste. But now she is back to her original state.
The weather has been cold & is now wet.
bobknott is offline
post #10 of 21 Old 01-26-2013, 02:16 PM
ZB_WJ
Do you still have lights? Sounds like could be the starter. Those are so usually free to test at a parts store.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #11 of 21 Old 01-26-2013, 02:24 PM Thread Starter
bobknott
I did wonder about the starter, but usually you would expect to hear the solenoid click as you turn the key, but all you get is silence until it just starts.
bobknott is offline
post #12 of 21 Old 01-26-2013, 02:34 PM
ZB_WJ
^ true. Mine made a single click. May want to check/clean the connections to the starter at least. Mine had a lot of oily grease on it.
ZB_WJ is offline
post #13 of 21 Old 01-26-2013, 02:43 PM Thread Starter
bobknott
Good point especially with the amount of flood water I have been through recently.
bobknott is offline
post #14 of 21 Old 01-26-2013, 02:45 PM
ZB_WJ
There is a little clip on the top of the starter (should be the same for euro model) if that comes Unclipped, it won't click or anything when trying to start.
ZB_WJ is offline
post #15 of 21 Old 01-26-2013, 02:53 PM Thread Starter
bobknott
Many thanks. I will have a look.
bobknott is offline
